Something everyone might want to check with 5spds
Old Nov 22, 2001 | 03:36 PM
RussMaxManiac
Lately my shifter has felt really notcy and loose. I decided when I was replacing a burned out fog bulb, to check the bolts on my linkage. Well I found the one on the actualy shifter linkage was loose, So I tightended it down, and man what a difference it made on the shifter! It's easier to shift now!
Something you guys might want to check.
Old Nov 22, 2001 | 05:31 PM
RussMaxManiac
Re: Re: Something everyone might want to check with 5spds
Originally posted by yo_its_ok
Stock or STS ?
Stock. This is the bolt that is right next to the tranny where a rubber seal is there.
190hpKiLLA's Avatar
Granny Driven
Where exactly can I find linkage. Use easy terms please. No MDR,PER type ****. Thank you.
Old Nov 22, 2001 | 05:42 PM
RussMaxManiac
Re: Re: Re: Re: Something everyone might want to check with 5spds
13mm shifter linkage bolt or 14mm pivot bolt aimed towards the back or 10mm nuts ?
The one on the actual black rod that connects into the back of the tranny. has a NUT on one end and a bolt on the other. It goes through the bushing or something like that. That was loose.
Old Nov 22, 2001 | 05:51 PM
190hpKiLLA's Avatar
Granny Driven
Re: Re: Re: Re: Re: Re: Something everyone might want to check with 5spds
14mm Pivot Bolt
190hpkilla:
Remove the 5 bolts for heatshield, and there is a 14mm bolt that is pointing towards the rear of the car... Russ is talking about that.
Russ you should get a STS. Makes a lovely difference. I can hold rpms higher and shift later and faster...
Just one I have to tighten. I thought there are a lot? Thank you.
Old Nov 22, 2001 | 05:52 PM
RussMaxManiac
The one on the tranny!!! Not the shifter. I did nothing near the cat. The other end of the rod is another bolt that goes through the middle. That one!
14mm Pivot Bolt
190hpkilla:
Miket2006
Mar 1, 2021 03:55 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
homewrecker
Sep 24, 2015 07:01 PM
