Eletircal expert needed please!
Old Jan 7, 2010 | 03:23 PM
TomZ's Avatar
I have some interior leds that I added as courtesy lights,when the circuit is closed, its still bleeding out around 2.4volts to my leds, which is not enough to light an incandescent bulb, but is giving the led a very very low amount of light output (when it should be off), How can i stop the 2.4v from reaching the leds?
Old Jan 7, 2010 | 06:07 PM
JNCoRacer's Avatar
Just the tip.
Why not just put the switch the ground as opposed to he 12v side?
Old Jan 15, 2010 | 05:59 PM
erty67's Avatar
Decal Specialist
put a bigger resistor on the LED
Old Jan 17, 2010 | 09:04 AM
mysticalone's Avatar
i would add a relay or a toggle switch.
Old Jan 17, 2010 | 10:15 AM
Mr. Brett's Avatar
You just need a lead with a bigger resistor. It should cost you a total of maybe $4 from Radioshack.
Old Jan 26, 2010 | 09:52 PM
eventnick's Avatar
I understand LED's but I don't understand your post. Can you put up a schematic of your circuit?
Adding a larger resistor will only decrease current flow through the LED... meaning unless it is sufficiently large the LED will still have a glow even if very faint.
Alternatively you can also add several diodes in series such that the turn on voltage is higher than whatever the 2.4 volts you are talking about.
Old Jan 29, 2010 | 08:01 PM
67whitegoat's Avatar
+1...What type of switch are you using? You don't have it on a rheostat do you? Where Are you tapping off for you 12v?
Old Jan 30, 2010 | 07:22 AM
Matt93SE's Avatar
STFU n00b!
Zener diode...
Matt93SE
May 24, 2019 02:58 PM
smplyamzng
Dec 13, 2015 01:19 PM
boomerbrian
Nov 8, 2015 05:10 PM
TonyJr
Aug 20, 2015 12:14 AM
