LED Modders Plz help.
Old Feb 20, 2010 | 08:19 AM
crazthe1nonly's Avatar
im planing on doing blue leds. all over the interior. including dash and speedo. i can do all the work myself but i need sum1 to tell me what leds / resistors i need exactly. where they can fit, and where is the best place to buy em.
Old Feb 20, 2010 | 10:11 AM
schmellyfart's Avatar
Your cheapest bet would be ebay. Use http://ledcalculator.net/ to calculate what resistor you need using the led specs listed from whereever you are buying them from.
Old Feb 20, 2010 | 12:14 PM
aackshun's Avatar
On the 4th gen window switches you don't need resistors, I would assume the 5th gen wouldn't be any different.
Good luck, and don't forget to update us w/ pics!
Old Feb 20, 2010 | 12:44 PM
HMAX08's Avatar
PM member thealliance43. he is an LED superstar, lol
Old Feb 20, 2010 | 05:16 PM
DrunkieTheBear's Avatar
Turbo'd Saab
If you order off ebay for the LEDs, you need 3mm and 5mm sizes, they will usually come with the Resistors that are good for your LEDs. I would look for some with a Flat top as it helps to not create hotspots and tend to give you a wider angle and better output.
Like it was said above you don't need resistors for the door switches but for the climate control you do. I don't have steady hands in fact I'm like Micheal J. Fox on caffeine. So I had a friend soldering the resistor really close to the LED.
Resistor on the positive side btw
Old Feb 20, 2010 | 07:07 PM
Sanding the leds also helps with the hotspot issue
Old Feb 20, 2010 | 07:39 PM
03VQMAX's Avatar
I used 3mm & 5mm Mcd leds, resistors would be 470 ohm 1/8W, check out the link below and see the list of exact leds I used.
Old Feb 25, 2010 | 04:56 AM
Bjboelke's Avatar
http://www.besthongkong.com/index.ph...msblj6v8a86gc2
http://www.oznium.com/
here are a few sites that has some pretty reasonable pricing
Old Feb 25, 2010 | 05:25 AM
ray08max's Avatar
how do i get led installed on my speedometer? i got an 08 max?
Old Feb 25, 2010 | 08:15 AM
nissandrvr98's Avatar
dude..first dont thread jack and second, stop whoring up this forum. wait your turn then start your own thread.....and SEARCH!
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
