$300 super charger option
Old Dec 7, 2001 | 02:23 PM
JerryT's Avatar
http://www.electricsupercharger.com
1psi of boost
4-12 HP gain
WOW! What a bargain for such terrific gains!!!
Old Dec 7, 2001 | 02:51 PM
Canuck's Avatar
A 98 max owner was one of the testimonials. Anyone know who it is?
Old Dec 7, 2001 | 03:09 PM
emax02's Avatar
I never heard of this thing before. Does it actually add HP?
Old Dec 7, 2001 | 03:22 PM
Anachronism's Avatar
No, there are a couple of old threads on it, search. Someone actually lost a couple HP with it.
I think it is a problem of 12 volts not being enough to produce usable boost. Any electrical types know if it would be possible to wire a second (or third) battery (or capacetor) in parallel to increase voltage and make an electric supercharger that really works?
Old Dec 7, 2001 | 03:40 PM
Lordrandall's Avatar
Jerry Jerry Jerry, you should know better.
shame.
Old Dec 7, 2001 | 04:16 PM
Eric L.'s Avatar
It sounds like a silly product. It only activates at WOT, so unless you regularly floor the gas pedal, which would be a dumb thing to do in a Max from a standstill since the front tires would just spin and smoke up.
Unlike a real SC, where you have extra power all time, regardless of throttle position.
Old Dec 7, 2001 | 06:18 PM
eric93SE's Avatar
Yeah you would loose HP if you wired it backwards
Old Dec 7, 2001 | 06:56 PM
ereet's Avatar
Better cheap supercharger:
Find some guy really hard up for money, sit him under your hood, have him blow into your air intake tube for $20 bucks. Wheee!
Old Dec 7, 2001 | 07:08 PM
mAdD MAX's Avatar
But that would add weight Rob...weight != good
Old Dec 7, 2001 | 07:29 PM
ereet's Avatar
There's a lotta boneracks downtown, I'm sure if you searched around you could find a really skinny guy or a midget
Old Dec 7, 2001 | 08:15 PM
AznWontonboy's Avatar
Thats Carbon Dioxide, not oxygen.. Oxygen is what ya need, duhhhh.
Old Dec 7, 2001 | 08:30 PM
JerryT's Avatar
shame.
!--shruggs shoulders--!
What'd I do? I'm just try'n to help you guys get better performance.
!--wink, wink--!
Old Dec 7, 2001 | 09:12 PM
Nismo's Avatar
add a tornado to one of these bad boys and you'll get real power
Old Dec 7, 2001 | 09:46 PM
KCTYPHOON
if you search on the bmw forum youll find alot about that pruduct.. his the numbers really dont add up. AND, when the fan is not running, your restricting your intake
Old Dec 7, 2001 | 09:48 PM
NYCe MaXiMa's Avatar
they say "guaranteed"
anyone want to buy one then dyno your car?
Looks like a regular intake to me
Old Dec 7, 2001 | 10:24 PM
93_MaxSpeedMark's Avatar
I looked at the demo video, and the thing actually flies outta the guys hands...I think i'll be the guinea pig...It couldn't hurt, and if it does, I'll just put my CAI back on.
Old Dec 7, 2001 | 10:30 PM
KCTYPHOON
your wasting your money.. read up on it.. i found that site a few months ago.. youll be lucky if you break even.. the lil horspower it makes is barely makin up for what your loosing just to turn the thing on
Old Dec 8, 2001 | 12:29 AM
Nismo's Avatar
well, if you ever get it, be shure to tell us what u think about it
Old Dec 8, 2001 | 02:07 AM
black019's Avatar
get a turbonator on top of that and you are set
www.turbonator.com
Old Dec 8, 2001 | 02:36 PM
SLC I30t's Avatar
Daniel B. Martin and I did a little research project talking to fan and blower vendors trying to find out what kind of power usage and fan types to create a constant 3-9 psi in the intake manifold threshold. Basically there were 3 companies that could make these fans on a 12 volt power source, but it would cost nearly 5k. One company said they could do it cheaper but feared that the cost savings would leave you with less than optimal bearing and motor. Leaving it with a short spin life, maybe 100-200hrs. So it's possible, but not realiable for an application such as ours. Sorry.
Old Dec 8, 2001 | 10:34 PM
philpoe's Avatar
4 Maximas and counting
From the research that you've done...
Could a more reliable and/or less expensive blower be made with a 30v or even a 42v source?
Old Dec 9, 2001 | 07:59 AM
SLC I30t's Avatar
No we didn't, we were only looking at it on a bolt on feature for the common car. The biggest problem was that the motor would have to be pretty small or have it belt driven off of a satelite motor. And there are motors and fans that will move that much cubic ft of air but the motor would have to beable to spin the rotors at like 25k rpms a minute or more. to provide that 3-9lbs of pressure. Plus when you had it turned off it would restrict air flow. So in time I would assume that technology might allow it to happen, but its not there yet.
Old Dec 9, 2001 | 08:19 AM
costcowholesale's Avatar
get like a 100000000000000000 feeet hose and suck it to his mouth an d the intake, have it blow air @ home
Old Dec 9, 2001 | 09:41 AM
Rancid90SE's Avatar
yeah thats not a bad idea,but when you mount this guy under your car to blow his warm breath into your intake,hes gonna weigh at least 150 so you would (according to the 100lbs=.1 seconds rule) would probably end up slowing your car down
NOW if you want real genuine front wheel horsepower and low end torque,simply take off both windshield wipers,throw away the driver side wiper and raise the passenger side wiper to give you the "1 wiper effect" i have heard gains of up to 12 hp and 14 ft lbs. of torque from this mod
Old Dec 9, 2001 | 10:14 AM
ereet's Avatar
Hahahaha. Yeah, you'd have a problem though everytime you crossed streets though cause people would run over the hose and cut off your intake supply
Old Dec 9, 2001 | 10:16 AM
ereet's Avatar
Gotta be a midget or a skinny guy.. Get him to suck down a bucket of ice before he starts and you're good to go!
As for the wipers, we all know that driverside wiper weighs a good 300lbs. Why else would people do that?
Old Dec 9, 2001 | 12:11 PM
KCTYPHOON
ok.. for the simple fear of ridicule i wasnt gonna post this earlier. i was trying to figure out the best way to mount a 120v motor, such as a small leaf blower or a shop vac engine running through the intake. so i did alot of looking around , even went out and bought the perfect motor for the project i had in mind, until i found this site.. give it a look and tell me what you guys think. i was glad to see i was at least not the only moron with the idea, but not for nothin, it seems to me that he had more of an electrical problem then anything, so im still wondering.. if any one is serious about tryin to do somethin like this i have alot of good ideas so feel free to ask..
http://www.bimmers.com/m3/hoax/index.html
Old Dec 9, 2001 | 12:22 PM
SLC I30t's Avatar
I stopped reading after the W.A.S.T.E.O.F.T.I.M.E. part but what was his conclusion, other that he's a fool for cutting a hole in the hood of his M3?
Old Dec 9, 2001 | 03:08 PM
KCTYPHOON
listen.. im not gonna sit here and type the enitre story when you can take 2 min and just read it.. its not that long.
Old Dec 9, 2001 | 03:31 PM
AntGVR4's Avatar
it seems to me like a joke ..
the guy didn't really cut a hole in his M3...
Ant
Old Dec 9, 2001 | 03:41 PM
KCTYPHOON
Ant
no.. he really did... i still think the concept in do-able.. i think his power inverter went up in smoke.. i tried emailing these people about it but got no response..
Old Dec 9, 2001 | 03:48 PM
Sonic's Avatar
Hmm, all that extra air, and no increased fuel delivery...
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Redfox
Sep 28, 2015 10:41 AM
