Supercharger Tuning Poll
Old Dec 11, 2001 | 06:33 AM
MardiGrasMax's Avatar
I was wondering if all you Supercharged Maxima owners who have upgraded your pulleys for more boost would car to share some information.
What Gen? 4th or 5th
What SC kit? V1 or V2
What pulley?
What actual boost level at redline?
What FMU disc? stock or 8:1
Peak EGT readings after a full run?
Fuel pressure at full boost?
Spark plugs? Stock, one step colder...
Track times or dyno numbers?
Any other usefull tuning info.
I'm doing a little research....
Old Dec 11, 2001 | 06:37 AM
Re: Supercharger Tuning Poll
What Gen? 4th
What SC kit? V1
What pulley? 3.25
What actual boost level at redline? 8.5psi
What FMU disc? 8:1
Peak EGT readings after a full run? 720c
Fuel pressure at full boost? 90ish
Spark plugs? NGK BKR7E two step colder
Track times or dyno numbers? 13.6@102
I ran 13.6 with one step colder plugs.
I pput the 6:1 fmu disc in last night and the car seems MUCH faster. EGT's were 780-790c after a full run.
Old Dec 11, 2001 | 06:39 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
What pulley?
- 5th gen
- V2
- 3.125
- around 10.5 psi (it's hard to read the gauge and pay attention to the road)
- 8:1
- never done a 1/4 run, but it's about 700C when I get near the end of 3rd
- no fuel pressure gauge
- one step colder
- no track times, and no dyno numbers
What are you researching? PM me if you don't want to post it here.
Old Dec 11, 2001 | 09:21 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally posted by yo_its_ok
5th
PowerDyne BD-11 A2.93 @ 10Psi, now XB1-A 12psi
9.75Psi , 12.7Psi
NisMo R33 Upgrade Fuel Pump. PowerDyne A10051-8:1
EGT ? Never thought if using one. Tomei read 15.2 WOT.
Fuel Press: 92-98
Spark plugs NGK Iridium, one colder
13.55 @ 102, 12.72 @ 110, unofficial G-Tech: 12.31, Blitz Chasis DynoMeter: 341Hp.
Spearco FMI, ERL Water Injection, IMPUL ECU, IMPUL Fuel rail w/ AN fitting, SS Lines. IMPUL NS01R lightweight wheels, Forged Magnesium TE37 w/ 26x10x15 M/T Slicks.
I refuse to post pics.
got pics?
Old Dec 11, 2001 | 09:23 AM
DanNY's Avatar
Ad·min·is·tra·tor
Yes, but I refuse to say another word...Why ? Certain people on this forum know why.
-Peace
email them..or send me a link to them..
ru too busy for spacers now?
Old Dec 11, 2001 | 10:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
Dan, you'll see them like everyone else will, including, the doubters in March 2002. Spacers, have them, your bulbs, however, due to death last night, of my friend thanks to him speeding, I'm trying to comfort his family on the phone every 10 minutes or so.
-Peace
damn you're having a rough month...well let me know when you're rdy.
Old Dec 11, 2001 | 12:12 PM
Y2KevSE's Avatar
Jane97SE
- 4th gen
- V2
- 3.25
- about 10 psi
- 8:1
- no EGT because I think I lost the probe.
- one step colder plugs
- no track numbers, but dynoed at about 230 with stock pulley (3.60) and GReddy
Old Dec 11, 2001 | 12:21 PM
Jeff92se's Avatar
I'm needing a caw
How did the car run on the 6:1 disc and the stock pulley? Maybe Mardi should include emissions test too. ie.. ran rich on 6:1 or lean etc..So stock sc is about 8 psi? Hmmmm.
Where can I get some fittings for the in/out lets on the Vortech FPR?
Any store?
Old Dec 11, 2001 | 01:09 PM
Any store?
I never ran a stock pulley
Stock is suposed to be ~6psi peak at shift point.
It is leaner on the 6:1 but not soo much that it is detonating.
You can get fittings for the Vortech FMU from most autopart stores or even home improvment centers. The female threads on the FMU are 1/8" NPT. Then you just need to know what your comming out to, hose or pressure fitting. I just used high pressure fuel injecton hose. I forget what size but it should be the same as stock. Take a piece off and bring it with you to the store to be sure you get the right size.
Old Dec 11, 2001 | 01:18 PM
Jeff92se's Avatar
I'm needing a caw
6 psi? Even better! Thanks for the info. I think I've seen these fittings at the Home Depot or something. Napa carries good fuel injection hoses.
Old Dec 11, 2001 | 01:24 PM
Y2KevSE's Avatar
I can see Jeff hunched over rubbing his hands, grinning, and plotting evilness...
Old Dec 11, 2001 | 01:35 PM
DanNY's Avatar
Ad·min·is·tra·tor
Jeff..
http://www.mcmaster.com/
for AN..
www.anplumbing.com
you're welcome.
oh wait...am i being nosey?
Old Dec 11, 2001 | 01:52 PM
Jeff92se's Avatar
I'm needing a caw
Haha!
thanks for the links. others will benefit also. can I start calling you Lordo Type GTR? hehe.
Originally posted by DanNY
Jeff..
for AN..
www.anplumbing.com
you're welcome.
Old Dec 11, 2001 | 01:53 PM
Lordrandall's Avatar
Old Dec 11, 2001 | 02:01 PM
DanNY's Avatar
Ad·min·is·tra·tor
Haha!
there's only 1..Lardo..err Lordo..oops
Old Dec 11, 2001 | 02:37 PM
Old Dec 11, 2001 | 07:43 PM
Jeff92se's Avatar
I'm needing a caw
Hey when you guys are seeing high EGTs, are your water temps increasing also? Or are you guys raising the EGTs too fast for the water temps to start reacting??
Old Dec 11, 2001 | 08:07 PM
Shadow's Avatar
Is the 8:1 disc going to make my car run too rich? I have the 3.33 pulley. I also have nitrous, so I'm not sure.
Old Dec 11, 2001 | 08:31 PM
These are EGT spikes at full throttle. Normal NA Maxima EGTs are ~770c at full throttle in third or fourth gear.
Old Dec 11, 2001 | 08:35 PM
If it runs fine with the 6:1 I'd stay with that. But as you get close to 10psi of boost the 8:1 may be necesary. With an EGT gauge or near wide band A/F gauge or some dyno tuning you will know for sure.
Old Dec 11, 2001 | 08:49 PM
Shadow's Avatar
EGT gauge is on the way. So I guess I'll find out soon. What's a good temperature range?
Old Dec 11, 2001 | 09:35 PM
max'n out's Avatar
Vortech v2 5th gen still stock
HOw fast? It a honda killer
Going to upgrade to the 3.25 pulley with 8:1 fmu Or maybe it should be the 6:1 whatta think?
Old Dec 11, 2001 | 09:37 PM
Confused's Avatar
Permanent Maxima.org Resident
4TH GEN
What SC kit? V1 or V2 V1
What pulley?
3.33
What actual boost level at redline? .4 BAR, CAN'T BE RIGHT
8:1
NO EGT
NO F/P GAUGE, SHOULD GET ONE SOON
ONE COLDER
13.7 @ 103.03, 260HP, TORQUE UNKNOWN, SHOULD DYNO AGAIN SOON
REPLACED FILTER WITH 7 X 4 PANCAKE
ACT STREET DISC
HD MOTOR MOUNTS
QUAIFE NOT IN YET
2.5 Y PIPE, 2.5 RT CAT, 2.5 MANDREL B - NO RESONATOR, HKS 2K MUFFLER
FUTURE? V-2 W/ SMALLER PULLEY AND YOUR AWIC SETUP
FEEL FREE TO PM/IM/EMAIL/GET MY # FROM DELIO
Old Dec 12, 2001 | 06:57 AM
My Max with I,Y,E and one step colder plat. plugs, peaked at ~770c at the 1/4 mile traps.
My Max with I,Y,E + 100hp nitrous and one step colder plat. plugs peaked at ~810-820c at the 1/4 mile traps.
With 8.5psi of boost, 8:1 FMU disc, and and two step colder copper plugs I got 700c-710c at the 1/4 mile traps.
With 8.5psi of boost, 8:1 FMU disc ,35hp shot of just dry nitrous and two step colder copper plugs, I got ~720-730c at the 1/4 mile traps.
With 8.5 psi of boost, 6:1 FMU disc and and two step colder copper pligs, I got 780-790c at the 1/4 mile traps.
As a reference to A/F ratios when I dynoed with my 100hp shot I got ~12.4:1 A/F ratio. So you could assume that 810-820c is ~12.4:1 A/F Ratio.
Another SC member got 11.8:1 A/F ratio and was at 730c.
You can see how their related.
Old Dec 12, 2001 | 06:59 AM
Have a way to check the A/F ratio using a wide band sensor or EGT gauge I would say 8:1 to be safe.
Old Dec 12, 2001 | 10:45 AM
max'n out's Avatar
Gettin an a/f gauge before I do anything along with boost. Kev was saying get the 8:1 so thats what I was planing but sombody said the car was faster with 6:1 so just thought i'd put it out there to see what others thought.
Old Dec 12, 2001 | 03:36 PM
SuDZ's Avatar
-Peace
My condolences. I am very sorry to hear that. Was anyone else hurt in the accident?
SuDZ
Old Dec 12, 2001 | 03:44 PM
Jeff92se's Avatar
I'm needing a caw
Basicly yes, you are 100% right. hehe!
Y2KevSE's Avatar
Better safe than sorry.
Old Dec 13, 2001 | 10:01 AM
max'n out's Avatar
No, just my friend in his ghey GSX, I told him AWD won't save his a** all the time, eventhough it did a few times. All it takes is one time, and its all over. It's just real fuct up on how he lost control, and nailed a neighbors car, and his house was only up the street. Police report says, "Speed contest @ 75-85 mph when he went for fairly sharp right hander, misjudged where the curb was, and his rear slid out, and over compensation to the wheel, he plowed into his neighbors S4. His seatbelt buckle had broke, and the impact of the airbag @ 65-75 mph w/ practically no belt, you know what can happen.
Eclipses have a "cockpit" style interior and his motor was literally in the passenger seat. I won't get into the rest, but when I saw the car yesterday, scares me.
I'm sorry about your friend but I think something good can come out of it. Why not make this a sticky or somthing to draw everybody to look at it. Maybe just maybe some of those guys that keep talking about how they weve in and out of traffic at 120mph will stop and we can save a life or two. Again I'm sorry about your friend I know what its like to loose people suddenly do to speed and thinking they can do things they can't.
Old Dec 13, 2001 | 01:26 PM
gLok's Avatar
J, problem is I am one of those guys who weaves in and out of traffic. It's like some wierd ****, but everytime I'm behind the wheel, I get so spooked by the other drivers around me, I feel like "he" is gonna call me soon. Its wierd, like I said. After watching The Pike video over and over again, it made me regret alot of things I did that night, and it the way things have been happening around me, and on Maxima.org, all this speeding around is getting no one anywhere, just to the grave "faster"(If you wanna say that.)
-Peace
I feel you on this statement....I never say keep it safe cause people will do what they do, i just wish them the best of luck and hope no one is injured. I do a lot of dumbstuff myself and im lucky to have never been in a serious accident at all (knocking on every piece of wood attached to my desk)
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
