Sound System Problems
Old Jun 6, 2010 | 11:08 PM
NJ3ndri's Avatar
99 maxima se w bose sound system. i understand its outdated but wtf lol
I changed the headunit to an alpine and changed the speakers also to alpine. i still have the stock bose speaker amps wired in there and when i crank the volume over 18 it sounds like crap.
do i have to bypass the bose factory amps or something? ( i think theyre restricting these speakers of their potential)
I just want a clear loud system. im not trying to go too crazy with it
Old Jun 6, 2010 | 11:13 PM
Mralwaiz's Avatar
Yup... I just did this with my 2k and ran into the same problem. Im running alpine hu and type r speakers. run your speakers off of your own amp. the bose amp is not really compatible with any other speakers. I found a wiring diagram, and just tapped into the factory wires at the bose amp. 1000000000% better
Old Jun 7, 2010 | 07:44 AM
chrome91's Avatar
yep, thats right, the Bose amp wont work with other speakers
Old Jun 7, 2010 | 09:48 AM
NJ3ndri's Avatar
like a 4 way speaker amp?
theres like 4 to 6 wires going to the amps if i remember right. can i just use 2 of those wires straight to the speaker or does the bose got something else before that, that will still restrict it
Old Jun 8, 2010 | 08:51 PM
Mralwaiz's Avatar
Yea mate, a 4 channel amp will do the job. your pick on the amp(check ebay or pawn shops in your area for good cheap ones) depending on how you want it to sound. well in the 2k there is one sad bose amp under the rear dash, so i was able to tap all the wires i needed right there. Im not sure but yours may have individual sad bose amps for each speaker. If it does have amps at each speaker, then get to the factory amps and just bypass it by powering the speaker with your new amp.
**** Dont forget to get a wiring diagram if you dont already have one
Old Jun 8, 2010 | 09:40 PM
NJ3ndri's Avatar
yea i have the one with an amp for each speaker
Old Jul 6, 2010 | 06:43 AM
malv1's Avatar
The easiest thing to do is just run new wires from the speaker to the head unit... The factory Bose in Nissan/Infiniti vehicles is not really compatible with aftermarket equipment as demonstrated by the sound quality and to be honest all you are going to do is ruin your new stuff by doing so.
I would recommend running new wires to the radio or even a 4 channel amp if you want even more volume... Good luck with it!
Old Jul 6, 2010 | 10:47 AM
chrome91's Avatar
Originally Posted by Luther Wolf
Hello guys!
Take it in to the shop and have a professional look at it, you might need another amp, or more power so both can work at the same time...
spammer reported post, GTFO
Old Jul 6, 2010 | 11:45 AM
AlexxSCM's Avatar
yeah take it to a pro... i blew a kenwood amp ****ing around with the wires. it was new too and it was a sad waste of $200.
Bought a Memphis Audio amp and it is ammmmmaaaaaaazzziiiinnngggggg.
Old Jul 9, 2010 | 10:15 AM
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by Elis Ben
Greetings!
Thanks for sharing your informative trhoughts and Its possible that your windows is corrupted. But you can try get those cheap usb portable sound cards. It might solve the problem.
spam
Old Jul 11, 2010 | 09:41 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
you can use the stock bose wiring. if i remember correctly there are four wires to each. power ground negative and positive speaker connections. use a testlight to identify power, and you can hook the speaker wires behind the radio after identifying the colors. easy enough.
BkGreen97
Apr 2, 2016 05:47 AM
markevans999
Sep 10, 2015 04:29 PM
nbstriker10
Sep 4, 2015 04:26 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
