My key broke off in the ignition...help!
Old Dec 14, 2001 | 12:52 PM
bmxsteve's Avatar
I was getting out of my car today and started pulling out my key, without force, and half of it broke off in there. I can still put the other half in the ignition and it starts, but I want that piece out! The key is not magnetic and I dont think tweezers will get it either. What do I do? Is there a special tool made for this? thanks
Old Dec 14, 2001 | 01:24 PM
Jeff92se's Avatar
I'm needing a caw
If the key is not "locked" in there, you can try using superglue and a nail/pin/chopstick etc.. Put some superglue on the "stick" and try to get it to stick to the broken key. Wait and then try to pull it out gently.
Old Dec 14, 2001 | 02:12 PM
mzmtg's Avatar
Minister of Silly Walks
...and hope you havent glued the stick to the inside of your lock cylinder...
Old Dec 14, 2001 | 02:16 PM
Jeff92se's Avatar
I'm needing a caw
Well I haven't heard your bright idea? hehe.
Anyway if that happense, you can just use nail polish remover to unstick it. sheesh
Disclaimer:
If you don't have any common sense, don't try my method. hehe
Old Dec 14, 2001 | 02:27 PM
SuDZ's Avatar
That is nuts. It happened just as you pulled it out normally? Was it ever been or straightened before?
SuDZ
Old Dec 14, 2001 | 02:28 PM
gtr_rider's Avatar
192.168.1.1
Just one thing comes to mind when I read this
Very Smart
Old Dec 14, 2001 | 03:04 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Very Smart
Old Dec 14, 2001 | 04:07 PM
sinewave's Avatar
If you can still drive the car, take it to a locksmith's shop. They should have no trouble picking it out, shouldn't cost more than $10-$20, and you can have a new one made while you're there.
Old Dec 14, 2001 | 04:41 PM
NickStam's Avatar
hmm....that seems hard to do . How bout solder the key back together and try to pull it out
Old Dec 14, 2001 | 05:25 PM
UMD_MaxSE's Avatar
Got Bent?
solder will not stick on the key like that.
Old Dec 14, 2001 | 05:28 PM
NickStam's Avatar
i just really didn't have a good idea.
Old Dec 14, 2001 | 05:32 PM
Blackgums100's Avatar
The super glue idea sounded good,
why not put a tad of super glue on the end of the half in your hand, then insert your key, let it stay together and see if that works. I wouldn't use much, just a dab. Or a least call a locksmith for advice.
Old Dec 14, 2001 | 05:33 PM
UMD_MaxSE's Avatar
Got Bent?
it is ok, my friend. At least you tried
Old Dec 14, 2001 | 10:02 PM
DanNY's Avatar
Ad·min·is·tra·tor
get two paper clips..straighten them out.
bend the tips at a 45 degree angle.
try to push down on the pins of the lock and dig under the broken key with the two clips and try to pull it out. if it goes it more..just stop.
my $.02
Old Dec 14, 2001 | 10:46 PM
bmxsteve's Avatar
Yes, I did pull it out normally, no force. I guess it was just a ****ty key. It wasn't oem. I'm not a dumbass, I just have ****ty luck, you know?
Old Dec 15, 2001 | 01:30 AM
carnal_c30's Avatar
Former Sponsor
I dont fault you for what happened, it was just a ****ty key... but it is an unusual problem... haha
Old Dec 15, 2001 | 09:11 AM
gtr_rider's Avatar
192.168.1.1
Just get a genuine key from Nissan and have them cut it, how much would that really cost? $40?
Old Dec 15, 2001 | 09:52 AM
Weasel's Avatar
I've bent my Nissan key nearly 90 degrees... it didn't break, but it isn't any more resistant to it than a copy. Actually, my copied key for my brother's car is stronger than my Nissan key.
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 16, 2015 02:53 AM
jerrod99_se-l
Sep 19, 2015 06:54 AM
dcam0326
Sep 18, 2015 04:52 PM
