City where Maximas are built in Japan
Old Dec 16, 2001 | 07:16 AM
gurekku's Avatar
What is the name of the city in Japan where the Maxima is built?
Old Dec 16, 2001 | 08:01 AM
Sprint's Avatar
http://www.motortrend.com/july99/nissan/techdata.html
Oppama, Japan
Old Dec 16, 2001 | 08:12 AM
ericdwong's Avatar
http://forums.maxima.org/showthread.php?threadid=45742
its in the 4 gen Maintenence FAQ. I dunno why its under maintenence, but it is.. anyway check your VIN. Go to Position 11: (Manufacturing plant, T = Oppama, M = Tochigi)
Old Dec 16, 2001 | 08:28 AM
gurekku's Avatar
Oppama, Japan
Thanks. I found an on-line link to a map of the area (click on the "How to Get Here" button):
http://www.oppamabiblechurch.org/
Old Dec 16, 2001 | 08:30 AM
Sprint's Avatar
if you are going.. bring me back a VQ30DET
Old Dec 16, 2001 | 08:57 AM
Sonic's Avatar
It's a thread in O-T.net. 'Post the city your car is made in'.
Old Dec 16, 2001 | 12:19 PM
Sprint's Avatar
Originally posted by yo_its_ok
Want one ? I can get a 98 w/ 29,000Km on it for around US$3400(400000 Yen.) Add in shipping...
won't fit in your Max...
i can get one with 30k from Australia for $1500USD before shipping..
Old Dec 16, 2001 | 12:23 PM
Sprint's Avatar
Y33 CIMA ? w/ ECU ?
jaa jaa ..
Old Dec 16, 2001 | 12:41 PM
Sprint's Avatar
their website says $3000.. but the guy was going to hook me up..
http://www.sssautomotive.com.au/Nissan.htm
Old Dec 16, 2001 | 12:45 PM
Sprint's Avatar
Bhastard...I was wondering how you were getting it so damm cheap...I still have the short block if you want
i have a bent valve i think i will just rebuild on this block i guess i might be forced to take up that $1500 offer.. jeez.. i am so broke
Old Dec 16, 2001 | 01:03 PM
Sprint's Avatar
its not solid analysis.. i was talking to the guy at my performance shop and i told that my car was running rough.. and at one point it was ticking.. then he said its ither valve spring or bent valve..
i dunno exactly what it is.. it might be somethign simple.. but they would have to pull the engine down to find out.. so i dunno.. spring time i will deal with it..
Bent valve on a VQ ? How the hell ?
Thought the VQ ECU was smarter than that...I think all you'll need is a head job...might as well have everything done on intake manifold and TB.
Project SprintMax ?
I see bent valves on Honda Accords, automatic ones ...balance shaft seal leaks, gets oil on timing belt, push the engine too hard, timing belt teeth jump a few on the crankshaft, and then its all over... new head...
Old Dec 16, 2001 | 01:36 PM
Sprint's Avatar
its not noticably loud.. at least i haven't heard it since i change my plugs.. i have to pop the hood and go listen again
:doh: [insert pic]
running rough ? Ticking ? Valve lash adjustment...the way you beat the snot out of your car... I think its just valve lash, the shim probably has air underneathe it. Happened on mine after autoX, and a spin out. Synthetic + 5200mi on the oil+ AutoX = 1qt short of oil as checked in the pits, didn't solve the ticking problem, found out about the valvetrain, and 6 hours of removal, joy adjusting shims, putting back together w/ new gaskets...less noise, but not as bad, as like when my car sounded like someone was knocking on the hood...
Old Dec 16, 2001 | 11:27 PM
Max4U's Avatar
Y33 CIMA ? w/ ECU ?
Isn't the Q45 in japan called the Cima ?
Old Dec 17, 2001 | 07:41 AM
Sprint's Avatar
Cima has the body of a Q45 but the heart of a maxima
Old Dec 17, 2001 | 07:53 AM
Sprint's Avatar
well 88 - 92 they came with VG30DE and VG30DET and 93 - 95 they came with VG30DET and VH41DE and in 96+ they had VQ30DET and VH41DE so technically they have had the heart of a maxima well half of them
no cefiro/maxima comes w/ a VQ30DET...but technically, i guess so
Old Dec 17, 2001 | 07:56 AM
Sprint's Avatar
ai yi yi...wanna get technical...
ah2002
Mar 9, 2016 01:42 PM
stromm
Aug 27, 2015 04:13 PM
Team STILLEN
Aug 10, 2015 04:29 PM
