Car won't start after replacing injectors
Old Sep 20, 2010 | 06:03 PM
krazy6's Avatar
So one of my injectors went bad. I replaced all of them with some used 5.5 gen ones that I bought on here. I did Accelerator Pedal Released Position Learning and Throttle Valve Closed Position Learning before attempting to start the car.
Could I have missed a connector or something? Is there a specific connector that could keep the car from starting?
Everything works in the ON position, all of the dash lights work. Although when I try to start the car, the lights go dead and the car won't start.
Could it possibly be the battery?
Help me out, this car is pissing me off!
Old Sep 20, 2010 | 06:06 PM
howirole's Avatar
could be
Check for corosion on the battery connectors and check any of your grounds to see if they are loose.
Old Sep 20, 2010 | 06:10 PM
chrome91's Avatar
yep check the battery and alternator
Old Sep 20, 2010 | 06:27 PM
krazy6's Avatar
I'll check for corrosion. Thanks!
Old Sep 20, 2010 | 06:57 PM
krazy6's Avatar
Cleaned as much corrosion off as possible. Still won't start. The thing that is getting me, is that it won't even try to start. That is why I am thinking it could be a connector or something. I am 99.9% sure I did not miss a connector though.
Old Sep 20, 2010 | 07:44 PM
chrome91's Avatar
are the dash lights dim? if theyre dim, probably the alty
Old Sep 20, 2010 | 07:46 PM
VQ30MPG's Avatar
It'll turn over without injectors, so it's not that. How's your battery voltage looking?
Old Sep 21, 2010 | 03:39 AM
t6378tp's Avatar
Turbo 3.5
Need more info, does the car crank at all or does it just crank slow. If it is cranking are you get fuel and no spark or spark and no fuel.
It maybe something dumb like forgeting to connect the injector harness ground
Old Sep 21, 2010 | 08:10 AM
krazy6's Avatar
The car does not crank at all. Doesn't even try.
Old Sep 21, 2010 | 09:56 AM
t6378tp's Avatar
Turbo 3.5
I would start with the easy stuff and like stated before check everything you touched then everything around it.
Next check the battery, does your lights, radio, etc still work. Then I would follow-up by checking your fuses.
If everything is fine I would jump the starter to make sure it's good. If the starter works make sure the signal wire for the starter provides 12v when you turn the key. If it does not check your alarm if you have one or the ignition switch
Old Sep 21, 2010 | 10:17 AM
krazy6's Avatar
All of the interior lights and gauge cluster lights work so I don't think the battery would be completely drained. Maybe it's a fuse.
Old Sep 21, 2010 | 11:34 AM
njmaxseltd's Avatar
Interior lights and gauge cluster lights don't take anywhere near the same amout of power (Amps, not Volts) to light up then does your starter to turn over your engine.
Have the battery tested, or try to jump start the vehicle.
Old Sep 21, 2010 | 06:30 PM
krazy6's Avatar
Alright, got it started!
Tested the battery and it had 12.4 volts so I knew that was good. Checked the starter, doing the trick that T6378tp told me to do. That worked.
It then clicked in my head that maybe the clutch switch could be loose or something. Checked by the clutch pedal and the clutch switch was a little loose. Snapped it on, and it started right up.
Now the problem is the fact that it has a weird idle. It sounds like it is running on 5 cylinders or something. It doesn't have full power either. Feels pretty slow when I go WOT.
I tested the front three coils and they all seem good.
I think when the injector went out, it messed up the plug too. I am gonna check the plug tomorrow and see if that is the issue.
At least the car starts now. That made me happy.
Old Sep 22, 2010 | 05:31 PM
krazy6's Avatar
Car seems do be doing better now.
Still a slight hesitation. Might be one of the rear three coil packs.
Here is a question for you guys:
Can coil packs work intermittently, or do they just work or not work?
Thanks!
Old Oct 9, 2010 | 01:24 PM
Hellrot318is's Avatar
Coil packs work or they do not. At least I've never seen an intermitting one.
Old Oct 9, 2010 | 05:52 PM
chrome91's Avatar
i thought cracked ones kinda work?
Old Nov 8, 2010 | 06:24 AM
NoMam's Avatar
try your ground, maybe it was frid
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
Balkins
Aug 12, 2015 06:39 AM
