Courtesy FSTB fit's 02's and AE pedals don't fit{kinda}.
Old Dec 17, 2001 | 06:33 PM
emax02's Avatar
Today I installed my 00-01 Courtesy nissan FSTB, it just barely cleared the intake manifold by about 1mm. At first it was rubbing then I removed the bar and loosened it a tad and now it fit's perfectly! Now the AE gas pedal is of a different designe because the 2002 no longer uses a throttle wire. So I had to remove the gas pedal from my AE lever and install it on my oem gas pedal lever. When it was all said and done it fit pretty well, but it's just little wably, very little. The other pedals of course fit fine but they were a real beatch to get on! My left shoulder is killing me.
The pedals look great and the FSTB added a nice touch to the handiling characterstics of the car. I would post a few pics but photo point dissapeared a few day's ago and I have no clue what's up with that, I even payed them $20 for a year's worth of photo hosting to avoid crap like this, argh.
Old Dec 17, 2001 | 06:35 PM
emax02's Avatar
Sorry, I meant to post this in the 5th gen forum, oops . For some reason the delete function is not coruntly working?
Old Dec 17, 2001 | 07:28 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
y tank u ethan, i think i will be ordering one tomor... wait wait, nevermind, it's on the way
Old Dec 17, 2001 | 08:01 PM
PhatGuy
Paul D just installed his FSTB and RSB on his 6spd on Sunday and it looks pretty good and helps big time. Both him and Rick and putting H&R on their cars this friday as well! If you guys don't already have them you should install and intake as well.
Old Dec 17, 2001 | 08:08 PM
what intake are you guys using.
Old Dec 17, 2001 | 08:41 PM
emax02's Avatar
Cool, I am getting a Stillen intake in a few day's and the RSB is allready on.
Good to here Steve
Old Dec 17, 2001 | 08:47 PM
PhatGuy
They are using the Stillen.
Old Dec 17, 2001 | 08:48 PM
PhatGuy
Good to here Steve
What RSB did you go with? The Addcco (sp?) didn't fit well on the 2K2 that I saw it on.
Old Dec 17, 2001 | 08:50 PM
i got my stilled RSB to fit butt i don't want to get a POP. i want something with a tube. i might get a CAI and use half of it and think about the second half.
Old Dec 17, 2001 | 08:59 PM
emax02's Avatar
I have the Addco RSB on. While it was not easy to install it definatly fit on perfectly after some time. The U brakets were a little bit to narrow for a easy install, I had to work them in place and tap em with a hammer.
Steve, after seeing the dyno Phatguy's friend did I decided to just get a Stillen Intake. The guy picked up like 8-9 HP with his intake and muffler, I think the intake gave about 90% of the gains. I think this all the Power adding mods I am going to install, atleast for a while. I just wanted to have more HP then the damn TL-S's .
Old Dec 17, 2001 | 09:12 PM
PhatGuy
Tip
Well if you really don't want to pay more money, drill in your fender well, and have to worry about a bypass valve..water and crap etc.. Go with the Pop charger intake. Proven gains as well. I have a POP on my 2k1 and I took a 3" or 4" in diameter heavy duty flex tube (used for rain drain on a house). I cut a lip on one end (to help induce air) then installed it so the lip is just under the splash guard and angled it up to point right at the intake. I used small ties to install it and I feel it works great since my intake has never even been really warm after driving hard. The tube I used also had very small slits in it so it will give good air flow through that part of the engine bay as well. The faster you go the more cool air is blown on it (from below the splash guard). Bout 2 bucks for the mod with a 10 min install.
Old Dec 17, 2001 | 09:16 PM
emax02's Avatar
Phatguy, the 2000-2001 Stillen intake fit's a 2002 right? Just want to make sure .
Old Dec 17, 2001 | 09:29 PM
PhatGuy
I believe so but I think the install bracket is different but not sure? Check with Stealin or Paul at Avalon Racing.
Old Dec 18, 2001 | 12:07 AM
LaXor's Avatar
Is there any word on PR CAI? Id rather go cold than hot.
But damn I feel so slow trying to get my mods together. All I have ordered is clear side markers and strut. I need more money
Old Dec 18, 2001 | 12:56 AM
lp's Avatar
lp
Re: Courtesy FSTB fit's 02's and AE pedals don't fit{kinda}.
Man, thats close. Whats happening at WOT?
Looks like I've been ripped by Photopoint too, this kind of **** has happened before with them.
Old Dec 18, 2001 | 01:18 AM
emax02's Avatar
Re: Re: Courtesy FSTB fit's 02's and AE pedals don't fit{kinda}.
I had my father rev my engine while I watched for clearance. The engine moved back and forth, not up and down, so it will never actually hit the intake manifold. I drove the car a bit too and the FSTB never comes in contact with anything.
Old Dec 18, 2001 | 04:39 AM
that's good to know ethan. i think i might wiat for a CAI to come out. i like the flexibilty of the tube and i can use just half of it if i want.
King_Ten_Ahead
Sep 30, 2015 04:27 PM
dinososexy2.6
Aug 31, 2015 05:37 AM
FlaMark
25
Aug 28, 2015 10:15 AM
Stagnet04
Aug 16, 2015 11:15 PM
