and stinking up the inside of the car whenever i have the air on. it looks like its about to go. i have matrix 90/100w bulbs in now, ill put my stock ones back in when i get home later tonite, but what do i do about it? the housing is all melted and cracking, and the light is a lot dimmer than the other bulb that isnt melting. is this an expensive boo boo? and should i keep using the matrix bulbs?
Quote:
you should NOT run higher wattage bulbs without APC Upgraded headlight harness.. if you have one.. then i would use a different bulb..Originally posted by magnum
Quote:
doh.. where can i get a new harness... if you know offhand, what wattage should i be running. i totally forgot to check the bulbs when i bought em.Originally posted by SprintMax
I have lower wattage bulbs and the upgraded harness and mine are still melting. Looks like I am gonna have to go with the real HID's.
Is your headlight HOUSING melting or the HARNESS? I fried my when I ran 80/100W bulbs in mine.Originally posted by magnum
You can make your own by buying the 9004 connector harnesses from PEPBOYS and wiring up a relay straight to the battery like I did.
