Low Idle & CEL Light on from Apexi RSM?
Old Dec 19, 2001 | 04:57 AM
Synki's Avatar
I just installed my Apexi Rev/Speed Meter yesterday and decided to test it out. After a full day of driving, the idle in "D" at a stop light, i noticed the rpms dropped to about 500rpms. It still idled smooth but i wasnt fond of the low rpms.
After my last top speed run, my CEL light popped on. I was very puzzled. I think it might hav esomething to do with the RSM since it removed my limiter. I iwll have the code pulled today after class.
Also, the RSM doesnt retain memory? I tapped the wires like i should but everytime i shut it off, it takes an extra 5 seconds for it shut off. Everytime i start the car, i must reprogram it.
Any ideas?
Oh yea, the RSM def did remove my limiter. I did two top end runs. The 2ns top run i actually walked a old RX-7. It was prolly NA but it had a loud exhaust and it backfired when he shifted. Anyways, i stayed even with him at 90mph and started walkin hom from there. At 130mph i had roughly 3-4 cars on him. He got spanked by an auto w/ NO NOS and two fat kids.
Old Dec 19, 2001 | 06:12 AM
Stereodude's Avatar
Re: Low Idle & CEL Light on from Apexi RSM?
You're two fat kids? Buying clothes must be kinda hard then.
Stereodude
Old Dec 19, 2001 | 06:18 AM
Sprint's Avatar
did you pull the code?
jeez you could have saved all that money and cut the wire and get he CEL anyway
Any ideas?
Old Dec 19, 2001 | 06:43 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Low Idle & CEL Light on from Apexi RSM?
u like rigging **** on your car enh?
Old Dec 19, 2001 | 06:47 AM
Sprint's Avatar
Re: Re: Re: Low Idle & CEL Light on from Apexi RSM?
wires everywhere like you wouldn't imagine bro
Old Dec 19, 2001 | 06:59 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Low Idle & CEL Light on from Apexi RSM?
birds nest?
Old Dec 19, 2001 | 07:20 AM
Sonic's Avatar
Re: Re: Re: Re: Re: Low Idle & CEL Light on from Apexi RSM?
birds nest?
No, fire waiting to happen.
Old Dec 19, 2001 | 07:21 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Hmmmmm...... I installed mine last Friday and I haven't run into any problems yet. There were no 5th gen instructions, so I had to look at the ESM for the correct wires to splice into.
Maybe you should check your FSM to see if the pins are the correct ones.
Did you get the G-sensor too?
http://wwwcsif.cs.ucdavis.edu/~chin/images/Maxima/rsm
Old Dec 19, 2001 | 07:31 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: Low Idle & CEL Light on from Apexi RSM?
how do u assume that?
Old Dec 19, 2001 | 07:32 AM
Sonic's Avatar
Re: Re: Re: Re: Re: Re: Re: Low Idle & CEL Light on from Apexi RSM?
I know how Doogie rigs things.
Old Dec 19, 2001 | 07:34 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: Re: Re: Low Idle & CEL Light on from Apexi RSM?
darren joo mean?
Old Dec 19, 2001 | 07:38 AM
Sonic's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Low Idle & CEL Light on from Apexi RSM?
darren joo mean?
Hmm, I thought we were calling Darren Doogie now. I guess not...
Old Dec 19, 2001 | 11:00 AM
sx7r's Avatar
it does retain memory. that's insured by the constant power wire aside from the ignition 12v wire. apexi stuff stays on for a few seconds after you turn off the car, ie s-afc, rsm. when you get online later, tell me exactly which wires you tapped into for power.
Old Dec 19, 2001 | 12:15 PM
delio's Avatar
You noticed too huh? I thought it was just me.
Old Dec 19, 2001 | 01:23 PM
nismo2020's Avatar
Needs non-Maxima Friends
Old Dec 19, 2001 | 01:46 PM
Whitemax's Avatar
Disco Biscuit
LEt me tell ya. I went the Doogie route and it is bad azz for a free mod since I had a spare switch and wire. Although it looks nowhere near as cool as the Apexi Unit...
Old Dec 19, 2001 | 01:53 PM
Sonic's Avatar
And you get to have a supercool red light on your dashboard.
Old Dec 19, 2001 | 01:56 PM
Synki's Avatar
Yea, i will check wiring again. Does yours retain memory Keving?
Sprint's Avatar
the check engine light on GXE's are amber
Old Dec 19, 2001 | 01:59 PM
Whitemax's Avatar
Disco Biscuit
Hm, um I've never seen the CEL. Maybe I know what I'm doing, and you guys don't?
Old Dec 19, 2001 | 02:00 PM
Synki's Avatar
I know when the CEL light is on, the car should be running in "safe" mode. It will stay that way until reset. THe car shouldnt have any difference in performance though.
Thomas-I used the writing from you on teh manual. I htink the constant is wrong and might be causing the low idle problem. I figured it wasnt suppose to loose memory. Did your CEL light ever come on when you did 150? It popped on after i hit 130mph racing the rx-7.
The ECU code was P0500 which is for speed sensor (b/c i was doing 130). I used my friends scanner and also resetted it. People around me charge $70 to pull codes! Thank god im good friends with him and i get to use all his tools & shop for free.
Old Dec 19, 2001 | 02:15 PM
Sonic's Avatar
That's not normal. All lights that need immediate attention in a car are always red. Hmmm....
Old Dec 19, 2001 | 03:20 PM
Y2KevSE's Avatar
Yes it does Stynki.
FSM + research = no CEL
Double check to make sure.
Old Dec 19, 2001 | 03:24 PM
AntGVR4's Avatar
my CEL is amber
Ant
Old Dec 19, 2001 | 03:27 PM
Synki's Avatar
Yes it does Stynki.
What does the G-Sensor do? I have the older version. As long as it removes my governor, im happy.
Old Dec 19, 2001 | 03:40 PM
Y2KevSE's Avatar
It does G's silly.
Old Dec 19, 2001 | 04:14 PM
Y2KevSE's Avatar
Originally posted by yo_its_ok
G sensor gives you bragging rights about your "weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-factor."
.81 horizontal... easily.
Old Dec 19, 2001 | 04:25 PM
Y2KevSE's Avatar
Ordered mine today as well...but it aint going in a Maxima...
What are you putting it on?
Old Dec 19, 2001 | 04:29 PM
Sprint's Avatar
Dad's new toy. The Ultimate 4 Door Sedan available in the US.
Got my UUC STS/AC Schnitzer Shift **** for it, mod day tommorow
Holden Commmodore
Old Dec 19, 2001 | 04:31 PM
Y2KevSE's Avatar
0-300 km/h
Old Dec 19, 2001 | 04:58 PM
Y2KevSE's Avatar
temptation is bad... X(
Once wouldn't hurt, right?
Old Dec 19, 2001 | 05:08 PM
Synki's Avatar
Arg, damn CEL is back on. I better unplug it till in get a chance to hook a new constant up.
Old Dec 19, 2001 | 05:10 PM
Synki's Avatar
Oh yea, anyone know a constant wire off of the harness for a 4th gen?
Old Dec 19, 2001 | 05:11 PM
Y2KevSE's Avatar
I believe your power pin is in the upper right corner of your ECU (at least that's what I remember seeing for the A32).
Old Dec 19, 2001 | 05:28 PM
Y2KevSE's Avatar
1st row of three ...upper right ...apexi diagram N6-a
I'm wondering if Synki used N4-a diagram ?
I hope not... the ECUs look totally different.
Old Dec 19, 2001 | 05:53 PM
Y2KevSE's Avatar
I know I was looking at it in my RSM manual too...
Drunken Synki under the the dash ?
I hope he spliced the correct wires or *BOOM* sooner or later.
Old Dec 19, 2001 | 06:00 PM
Y2KevSE's Avatar
I wish I had a camcorder to record the sound my tranny made when it let go and the things I said in the cabin smelling burnt ATF...
*BOOM* = +
Old Dec 19, 2001 | 06:22 PM
Y2KevSE's Avatar
Old Dec 19, 2001 | 06:46 PM
Synki's Avatar
Im not sure which one but it was already labeled from Thomas when i got it from him. I think i just picked teh wrong wire for constant.
Old Dec 19, 2001 | 06:48 PM
Synki's Avatar
Nah being a drunk is for teh weekend but i am chillin back havin a 6.
The only wire that was wrong was constant. THe other wires are right. Its not connected right now.
