replacing antenna mast - stuck
Old May 27, 2011 | 05:33 PM
BEJAY1's Avatar
Conecarver
I read through a dozen threads, but I can't get the bottom of the power antenna mast out of the motor housing.
It seems there's a small metal flange at the bottom of the mast that I can't get to slide out. Does the 1" plastic piece need to come out too? It's not the cable or gears or anything like that.
Here's a video of what I'm talking about.
http://www.youtube.com/watch?v=rI5OBNufW0s
Thanks all!
Old May 28, 2011 | 08:14 AM
BEJAY1's Avatar
Conecarver
mast finally out
Today I went back at it with some suggestions from
http://forums.maxima.org/4th-generat...mast-help.html
Threw the motor housing into a vice, grabbed the mast with some vice-grips. And banged away with a 20oz hammer. After a dozen blows the mast finally released. As you can see here there's a metal sleeve fixed onto the end of the mast. It's got a tiny lip wider than the mast and that combined with corosion fixed it into the top of the plastic tube pretty snug. I did not use penetrating oil but perhaps that would've helped last night.
Old May 29, 2011 | 07:05 PM
Laevateinn's Avatar
The metal sleeve is the ground sleeve. I think it also keeps your mast from going all the way out. I think you can remove the tube that covers the mast.
Old May 30, 2011 | 11:34 AM
BEJAY1's Avatar
Conecarver
Thanks. The new one I got from ebay had a little bronze lip at the very bottom that prevented it from slipping in. I filed it down closer to flush so it could fit inside.
PH98I30
29
Feb 10, 2025 12:03 PM
MikesChevelle
Nov 23, 2024 11:17 AM
mvm062
Nov 30, 2020 09:00 AM
Rage Maximus
Sep 3, 2015 12:26 PM
A32goldylocks
Sep 2, 2015 06:39 AM
