Looking at getting a used car, need some opinions!
Old Jun 9, 2011 | 04:25 PM
bkortee's Avatar
Ok, I am looking to buy a jetta since my maxi is almost over 200k and im giving it to my son.
My question is:
Do you guys think it is worth it to spend an extra $1000 to $1500 on the 2007 GLI instead of the normal 2007 2.5 jetta? The GLI has the 2.0 turbocharged engine with 200 hp compared to the 2.5 liter 150 hp engine.
Also, do you think that the resale value would be better with a GLI or would they be about the same?
Appreciate the help. Thanks
Old Jun 9, 2011 | 04:57 PM
tigersharkdude's Avatar
GLI if you find one. Why not another Nissan?
Old Jun 9, 2011 | 05:34 PM
bkortee's Avatar
I actually was about to get an 06 from a family member but it didnt follow through. Decided to switch it up a little. Still will always be a nissan owner. Cant go wrong.
Old Jun 10, 2011 | 04:30 AM
Rydicule's Avatar
Don't you know who I am?
My question is:
Have a friend who got the GLI, and I would definitely think it worth it. If you were talking going from 200 to 250, or 220 to 270 hp, I might think otherwise... but going from 150 hp to 200 hp makes a pretty big difference.
And if the resale issue will depend on when you go to resell it. A 10 year old car will probably have minimal resale difference between trims, but you might be able to get a couple extra hundred regardless. A 5 year old car will most likely retain some resale difference between trims.
Old Jun 10, 2011 | 05:46 AM
MadMax07SL's Avatar
Going from a Max to a Jetta, you're going to be disappointed by the interior room IMHO...I test drove an 07 VW, think it was a Passat, and it was just tiny inside...like you'd be rubbin shoulders with your passenger up front. Came across the 07 Max and was sold immediately.
As to the choice, I would think the 200HP turbo would give you a lot more road confidence when faced with challenging circumstances...and I bet if driven moderately the Turbo will get near identical MPG's with the non Turbo, and should do considerably better then an 07 Max. Of course if you're rompin on it all day, mpg's are out the window...
Old Jun 10, 2011 | 06:14 AM
Mr.A32ftw's Avatar
cause the newer ones look like poop
Old Jun 11, 2011 | 09:32 AM
Bobo's Avatar
What has you sold on any Jetta? I was under the impression that they are very expensive to maintain. I would rather stay Japanese, than go European, unless money is no cosideration which it appears not to be your case.
Old Jun 11, 2011 | 12:31 PM
asand1's Avatar
I worked as a VW/Audi tech for a couple years and I really like them. The turbos are nice, very little lag with the variable AR. watch out for oil in the intercooler, and piping. Definately install an oil catch can.
Old Jun 11, 2011 | 12:35 PM
asand1's Avatar
Don't remember which was which, but one had issues with oil consumption due to rings. Another had issues with oil coking, the "fix" was a different oil filter. It really needed an external oil cooler imo.
Old Jun 11, 2011 | 12:37 PM
asand1's Avatar
Egress was water cooled and plugged up with carbon or aping a leak and exhibited head gasket symptoms.
Old Jun 11, 2011 | 12:39 PM
asand1's Avatar
EGR, stupid phone
Old Jun 11, 2011 | 02:42 PM
bigjoe's Avatar
get a max
Old Jun 14, 2011 | 03:57 AM
Rydicule's Avatar
That was the 5.5 gen Maxima.
Old Jun 14, 2011 | 03:59 AM
Rydicule's Avatar
Purely a myth. I spent more fixing and maintaining my 2002 maxima than I've had to spend maintaining my BMW.
Old Jun 14, 2011 | 11:31 AM
95Maxed's Avatar
GLI man, those engines can withstand soooo much boost. If i remember right, the 2004 GLI had rods in the engine capable of withstanding 800hp. They are very nice cars, but they are small. The only downside.
Old Jun 30, 2011 | 01:20 PM
loslobos's Avatar
GLI is a good choice.
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Feb 1, 2016 12:45 AM
twotonezed
Aug 16, 2015 08:10 PM
Tommy6905
Aug 14, 2015 11:54 AM
Samedi
Aug 13, 2015 04:05 PM
