Why does an air filter ->
Old Nov 9, 2000 | 02:11 PM
MaxedBandit's Avatar
make your car louder? It's kind of a pointless question but I haven't been able to find anyone that's been able to answer it. I've gotten "because your car takes in more air" and "your stock airbox covers something that makes noise" (this one was, I think, a really stupid answer).
Old Nov 9, 2000 | 02:15 PM
mzmtg's Avatar
Minister of Silly Walks
Thes second one was right...
The stock airbox assembly is carefully shaped and sized to eliminate most of the intake noise. When you yank all that off and just put an open filter, none of the noise is suppressed...simple...
Old Nov 9, 2000 | 02:17 PM
Jeff92se's Avatar
I'm needing a caw
The function of the stock airbox are:
1) Provide a reasonable amount of air to the engine
2) To provide the air from a reasonably cold source
3) To provide the air in a quiet manner.
If you get rid of the stock airbox, among other things, you lose #3. The stock airbox is designed to eliminate as much noise as possible sorta like the exhaust muffler.
Old Nov 9, 2000 | 02:19 PM
Keven97SE
...is actually the *right* answer.
The stock intake airbox is more than just some place to mount the filter. All the webbing inside is designed to stiffen the aitbox so that it doesn't resonate...the intake path makes quite a bit of noise, and the stock airbox deadens those sounds. It can't quite get rid of all the tones, though, which is why the intake path also embloys two resonators: a side-branch resonator right off the intake tube that lays on top of the radiator, and an inline resonator right before the throttle body.
Aftermarket cone intakes are loud, becuase the intake noise is only deadened by a thin filter layer, the sound deadening from the rigid filter box is GONE, and the side-branch resonator is no longer used.
The increase in airflow actually has very little, if nothing to do with the increase in noise. It's the fact that now the intake sound has a direct path right out the engine...through the thin filter media.
Old Nov 9, 2000 | 02:27 PM
TX2KSE
Like muffler baffles, in reverse.
Old Nov 9, 2000 | 02:59 PM
maxima561's Avatar
It could be based on the same theory as "Why does the toilet make noise when it flushes?"
Old Nov 9, 2000 | 03:01 PM
TX2KSE
Or, "If a tree falls in the forest with no one around to hear it...."
Old Nov 9, 2000 | 03:25 PM
ZuMBLe's Avatar
Whats the sound of one hand clapping?
ZuM
Old Nov 9, 2000 | 03:59 PM
Eric L.'s Avatar
If you look at the stock airbox, it has a resonator under the battery to muffle out the intake noise. In addition, the entire unit is closed (except for the scoop) so the noise is pretty much silenced. A cone filter is out in the open, closer to the driver than the scoop, and sucks in a bit more air. If you have cone, you will notice a hissing noise at idle. Notice how the stock intake doesn't make that sound? So, even at idle, a Maxima with intake is noticeably louder than stock.
BTW, I love the hissing sound. Makes the car sound wicked.
Old Nov 9, 2000 | 04:21 PM
got rice?'s Avatar
ZuM
whatch clapping your hand with?? (dirty joke! BAD Phuong BAD Phuong)
Old Nov 9, 2000 | 04:58 PM
Lordrandall's Avatar
Old Nov 9, 2000 | 07:27 PM
Vic's Avatar
Vic
where is that monkey?!!
Vic
Old Nov 9, 2000 | 10:42 PM
maximaisokay's Avatar
what does fart sound like? I always fart in silence like sssssss sssss ssssssssssssssssss.
John
Old Nov 9, 2000 | 10:47 PM
La Jolla Max's Avatar
John
If a tree falls over in a forest, and hits Maximaisokay...does anybody care?
Old Nov 9, 2000 | 11:01 PM
I will *****ing scream!!!!!!!
Old Nov 9, 2000 | 11:03 PM
why they block my "fu cking"???!?!?!? this site isn't for kiddies!!
Old Nov 9, 2000 | 11:06 PM
Then what're ya doin here?
Old Nov 10, 2000 | 07:20 AM
max95q's Avatar
maximaisokay: "Look mommy MAXIMA.ORG!"
mother: "No, Maxima.org is for grown ups, wait till you're all grown up and we'll think about it."
Old Nov 10, 2000 | 07:56 AM
whitymax's Avatar
my03maxima
Jul 28, 2024 07:40 AM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
