Twin Loop Muffler???
Old Feb 25, 2012 | 04:12 PM
  #41
AznRyan's Avatar
Originally Posted by Clashez
so your apart of the clone club ... no originality
Wasn't it your max that was a clone of the Mexican ricers?
Old Feb 25, 2012 | 04:48 PM
  #42
BobPezz's Avatar
I wouldn't be accepted into the clone club, since the SR*S isn't obnoxious looking or sounding!
But it's a known fact that to be a part of the clone club, it's mandatory to have a loud raspy potato launcher muffler, or something like this.....
Old Feb 25, 2012 | 04:55 PM
  #43
Crusher103's Avatar
Clashez just shut the **** up. You have absolutely NO knowledge on cars and should be the last person giving anybody advice or critiquing anything.
Old Feb 25, 2012 | 04:58 PM
  #44
chrome91's Avatar
Old Feb 25, 2012 | 05:24 PM
  #45
T_Behr904's Avatar
Old Feb 25, 2012 | 07:01 PM
  #46
Rods03Max619's Avatar
Twin Loop on the Max DONT DO IT....
Old Feb 25, 2012 | 07:11 PM
  #47
tigersharkdude's Avatar
I needz teh TRIPLE loop
Old Feb 25, 2012 | 07:21 PM
  #48
chrome91's Avatar
triple loop substitutes for 5lbs of boost, tru story
Old Feb 25, 2012 | 08:00 PM
  #49
AznRyan's Avatar
I am not worthy! :O
Old Feb 26, 2012 | 03:44 PM
  #50
ampire's Avatar
Just make sure you install a exhaust with merrell bends
Old Feb 27, 2012 | 10:00 AM
  #51
phatboislim's Avatar
I am not worthy! :O
nobawdii iz y0
Old Mar 1, 2012 | 07:38 AM
  #52
Dsquared97maxse's Avatar
so i was really hoping if i ignored this thread it would justt go away...
but on the plus side you guys helped me realize that i should leave the cheezy gimics to the a civic with 75 hp and fake chrome vents on the side.... lol
Old Mar 1, 2012 | 07:42 AM
  #53
And Clashez.. don't forget Clashez.
Old Mar 1, 2012 | 07:53 AM
  #54
give the guy a break lol it cant be as bad as starting this thread haha.
but im still looking for an exhaust and since im on a budget i figgured itd be cheaper to make my own. ive got a buddy with a metal working shop so ive got a place to weld, fit, and make the mandrel bent piping, but i wanna keep it quite. the cops and staties in R.I. are harsh on that stuff.
does any one have any resonator/ muffler suggestions???
thanx
Old Mar 1, 2012 | 04:22 PM
  #55
BobPezz's Avatar
thanx
For a nice economical system I suggest the SR*S Type-RE CatBack exhaust I mentioned in a prior post. I live in RI. too, and the cops don't even notice the exhaust. For more info on the SR*S, see this post; http://forums.maxima.org/5th-generat...ml#post8249660
I recommend checking out the linked post ASAP, since for some reason the sound file links get broken and won't work after a while.
Old Mar 1, 2012 | 05:17 PM
  #56
BobPezz's Avatar
thanx
Here's the link to the SR*S JDM CatBack exhaust for a 97 Maxima. From the same seller I got mine from. The seller is willing to bargain. http://www.ebay.com/itm/JDM-SRS-CATB...item335f45cf8a
It's not exactly the same as the SR*S Type-RE but is also priced lower.
Old Mar 1, 2012 | 06:56 PM
  #57
Yes SR-S over the twin looper...
Old Mar 5, 2012 | 04:56 PM
  #58
thanks BobPezz ive seen that one on ebay before for the 4th gen. ill still look into it but i was thinking somthing along the lines of like individual resonators and mufflers that i can weld onto pipes i place on there. i believe ppl on the .org have done it before but im not sure. either way the srs does sound good on your 5th gen.
Old Mar 6, 2012 | 05:01 AM
  #59
BobPezz's Avatar
Price wise you can't beat it for a good quality 100% stainless exhaust. You could probably deal with the seller and get it for ~$200. shipping inc. Price out individual parts needed and decide from there. Remember you'll need flanges, gaskets, bungs, hangers, hardware etc. The SRS comes with.
http://www.mandrelbendingsolutions.c...let/StoreFront
Old Mar 6, 2012 | 08:13 AM
  #60
Old Mar 9, 2012 | 06:01 AM
  #61
sergofast's Avatar
I havent laughed this hard in a long time...where the heck did you guys find this site.
Adjustable Powerband $249.95
Wish you had a little more low end torque? Maybe you want a high revving formula1-esque screamer? KaleCoAuto's Adjustable Powerbands are the perfect...
Boost Bar $159.99
Natural aspiration feel unnatural? Tired of bothering with duct-taped leaf blowers as turbos? Treat your car to a bar of boost. Most high performance...
Cross Drilled Brake Lines $69.95
Want improved braking? Why just cross drill those rotors? Introducing KaleCoAuto cross drilled brake lines! Improved airflow through lines provides...
Engine Oil Bypass Kit $49.95
Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block? KaleCoAuto bypass kit comes...
O Pipe (Dual Exhaust) $99.95
You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% back pressure feedback on ALL engines!!...
O Pipe (Single Exhaust) $89.95
Radiator Insulator $199.95
The weakest part of your car is the likely the radiator. It is a simple matter of physics when we tell you this: Energy is lost through heat....
Muffler Bearing $49.95
Do you have an annoying rattling in your mufflers? Are they sagging a little? Don't quite sound right? That could be the symptoms of a worn muffler bearing. Allow me to introduce the KaleCoAuto muffler bearing! It's unique iron-graphite composite with pre-grease-packed assembly provides over 200,000 miles of smooth muffler operation! It is most likely they will outlast your mufflers. Also works well on heavy duty exhaust systems. One per muffler.
Old Mar 9, 2012 | 06:23 AM
  #62
Old Mar 9, 2012 | 10:09 AM
  #63
Mr. Brett's Avatar
That kaleCoAuto site is pure win..
Old Mar 10, 2012 | 01:23 AM
  #64
Leo_Koneval's Avatar
Its late at night and for some reason, when I see the twin loop muffler installed on a car. It looks a little like when you have the unfortunate misfortune of bad misfortunes, to push a little too hard while on the can, and end up pooing your lower intestines out, then you just take it and hang it around your leg.
Old Mar 10, 2012 | 01:24 AM
  #65
Hey look I just quoted myself. Its a post within a post, its post-ception.
Oh, God I need to sleep.
Old Mar 10, 2012 | 07:00 AM
  #66
T_Behr904's Avatar
Old Mar 22, 2012 | 09:53 AM
  #67
does that site sell cross drilled fuel lines, ive been looking for them everywere but they dont have them. the guy at autozone told me they wouldnt help me cool my gas and would kill my mileage. what does he know though lmfaooooo
kjlouis
Nov 24, 2018 06:09 AM
Turbonut
46
Oct 21, 2015 08:28 PM
TheMafia
Sep 4, 2015 08:26 AM
mpbclutch33
Sep 1, 2015 09:24 AM
erictown
Aug 20, 2015 08:01 AM
