Hmm, shall I install the Y myself or pay a greasy mechanic ? Help please.
Old Jan 2, 2002 | 11:16 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Well my Cattman Cold air intake should be here anyday, and I have my WSP Y sitting here in my room. The CAI definatally I am gonna do, but I have heard mixed opinions on installing the Y-Pipe. I have a very knowledgable friend (who walked me through and did almost all my suspension) who is willing if I get the tools.
Lift wise, will a hydrolic jack and 2 jack stands be enough lift ?
Well I have a custom cat-back exhaust on the way and I have to pay to get that welded and what-not, as well as a front lip so I can't afford to really pay to install ALL of this. Do you guys think the Y is a duable project if given the proper common tools ?
BTW, If I got the peices of my cat-back system all welded together, could I install it or should I have the Mechanic do it ? I need him to weld it together but it doesn't seem too difficult to actually install myself. Thoughts ?
Old Jan 2, 2002 | 11:21 PM
Nismo's Avatar
Do it yourself. If you have the right tools. Jack stands and a jack is all you need. The only major problems that can happen is that you are not able to take off the rusted bolts or if the y-pipe has fittment problems (like many of us has had) then you should go to a shop. Just try it yourself first
Old Jan 2, 2002 | 11:24 PM
Craig Mack's Avatar
True. What do you think about the cat-back exhaust situation ?
Old Jan 3, 2002 | 12:13 AM
2000MaximaSE's Avatar
Do it yourself.. i was kinda hesitant to do it but got bored today so went at it... 6 tools will make it a breeze.. those tools are
1 deep socket ( dont remember which size..)
1 10" extension
1 3/8" ratchet
1 24" breaker bar
1 Universal swivel joint
1 O2 sensor wrench
these tools will make the job fly right by i used ramps to get at mine and it worked fine.. only took 2 hours cuz i had to wait for my friend to come over with a swivel
Adam
Old Jan 3, 2002 | 12:23 AM
emax02's Avatar
I say go for it Craig, I want to see you take some punishment .
BTW use a 14mm deep socket and also make sure to use a breaker bar.
Old Jan 3, 2002 | 12:32 AM
Nismo's Avatar
humm....Not shure about other options except you know someone with a wealder. If not then its probably something you have to take to the shop
Old Jan 3, 2002 | 12:38 AM
Jeff92se's Avatar
I'm needing a caw
If you are at all decent w/ basic tools the Y is DIY. Have the exhaust done at a shop and save the trouble. You can't really weld the pipe until they measure it all up on the car soo.......
Old Jan 3, 2002 | 01:07 AM
JDwyer2821's Avatar
I had the shop do mine because I knew it was going to be a ***** to get the damm bolts off. Hey it was worth the $65 plus the pipe did not fit perfect and they did the bending to make it fit.
Old Jan 3, 2002 | 06:09 AM
Washington DC Maxima's Avatar
Time is money
Take it to a shop.
Old Jan 3, 2002 | 07:09 AM
Whitemax's Avatar
Disco Biscuit
Aas much as I love doing my on installs, my shop is doing my Y while swapping out my tranny.
Old Jan 3, 2002 | 07:11 AM
JAY25's Avatar
You can do it is not hard
Craigmack you can take that Ypipe off yourself, there are 3 nuts per pipe except the rear which only have two. Prior to you loosening any nuts you will need a universal joint and a long extension to get to the the middle section of the Ypipe. The key is the WD 40 and the socket extension and definitely the Universal joint for the socket wrench. The Ypipe is a bolt on item is just about removing them 8 nuts and a couple of bolts that hold the stock one in place and thats it. I did it myself took me 1hr and a half. I think much easier then suspension if you ask me. Just loosen the center nuts first with the universal joint and then be careful with the O2 sensors youll see them prior to you taking the Ypipe off. Go to www.maximadriver.com and cheston has a write up on it. That is exactly what I used.
Old Jan 3, 2002 | 07:37 AM
sinewave's Avatar
Yeah, do it yourself. Use Liquid Wrench instead of WD-40; it is a much better penetrant. I suggest that you spray the bolts several hours before you do the work; you don't want to break an exhaust stud.
Also, a second pair of jack stands under the rear will give you a lot more room to work.
Old Jan 3, 2002 | 10:32 AM
Craig Mack's Avatar
i keel jOO
Thanks guys for all your responses. Looks like i'm goin to discount auto parts for sommore tools. I think we are gonna do my CAI, my Y, and an addco RSB on my sisters max, so we got some work ahead of us. The exhaust I guess Jeff is right since they have to weld it anyways might as well slap it on.
My red/clear taillights from DavidL should be coming here shortly. Is that an easy D-I-Y as well ?
Old Jan 3, 2002 | 10:37 AM
clee130's Avatar
Taillights are supereasy ... just be careful not to get the black glue stuff on your clothes or too much on your hands.
Old Jan 3, 2002 | 10:39 AM
Sprint's Avatar
Why do it yourself when you can watch the mechanic sweat..
Old Jan 3, 2002 | 10:52 AM
Craig Mack's Avatar
Old Jan 3, 2002 | 02:18 PM
Maxilicious's Avatar
Pay the $50-$60 for a greasy machanic to do it.
Old Jan 3, 2002 | 02:46 PM
Craig Mack's Avatar
Well the thing is I have to save that for my Cat-back exhaust system. And I have a friend who could easily do it given we had the proper tools. So, why not ?
Old Jan 3, 2002 | 02:56 PM
2DMax's Avatar
O2 sensor wrench?
Can you use a regular wrench, say an open ended wrench?
How hard is it to remove. I was going to get extras, but at $117 a piece, I rather not!
1 10" extension
1 3/8" ratchet
1 24" breaker bar
1 O2 sensor wrench
Adam
Old Jan 3, 2002 | 03:01 PM
Originally posted by 2DMax
O2 sensor wrench?
Sure u can, i just prefered the O2 wrench which is actually a 7/8inch socket with a slit up the side allowing you to slip it over the wires and sensor for the most grip. They pop loose in seconds with one of these bad boys.. it was like 12 bucks for the socket
Adam
Old Jan 3, 2002 | 03:48 PM
pmg's Avatar
pmg
If a shop will do it for $65,let them do it. You should have 4 jackstands also. I did mine. With my first y-pipe, it was made wrong and I couldn't get a big heat shield back on. Also, the bolts near the cat had to be chiseled off. They sent me a new y-pipe and I had it almost on and realized they didn't send the gaskets. Finally, on the third weekend, with new bolts at the cat that were almost impossible to find at a lot of stores, I got the new pipe installed. It was not made right either though and the o2 sensor rubbed on something and died a week later. I had to pay a shop to patch the old sensor hole and put a new sensor in a new hole they made. I am sure the pipes are made right now though as this was a while back. I'm just ranting and raving now because I had bad luck with mine.
Old Jan 3, 2002 | 03:49 PM
Guess I am just lazy and generally imaptient with these kind of things. Good luck.
Old Jan 3, 2002 | 03:50 PM
Vyrus's Avatar
I though you were a greasy mechanic Craig?
-Cyrus
Old Jan 3, 2002 | 04:05 PM
Craig Mack's Avatar
Thanks. I will need it.
Old Jan 3, 2002 | 04:07 PM
Craig Mack's Avatar
-Cyrus
Don't ***** up my thread bish.
Old Jan 3, 2002 | 06:07 PM
yourmove's Avatar
I do all mods myself but with the y-pipe I just decided to have it done. Fifty bucks and not having to deal with the rusted bolts were worth it to me. However you live in Florida, so you proly don't have the same challenge we do up here.
Old Jan 3, 2002 | 06:25 PM
Vyrus's Avatar
Sorry, I can't help it (Woohoo another *****!).
-Cyrus
Old Jan 3, 2002 | 06:27 PM
Sprint's Avatar
the front O2 sensor take a 22" open ended wrench
Old Jan 3, 2002 | 06:29 PM
Craig Mack's Avatar
You are right Danny. Guys like you and Sprinty's cars are all rusted and what-not, while her in nice warm florida our cars internals stay healthy and removeable.
Old Jan 3, 2002 | 08:35 PM
emax02's Avatar
Don't you mean externals? The internals are watter proof.
Old Jan 3, 2002 | 09:00 PM
ru4real's Avatar
Re: Hmm, shall I install the Y myself or pay a greasy mechanic ? Help please.
How do you think a poor greasy mechanic is gonna feel when he reads the topic? Have some compassion! He's all greasy! You're lumping all mechanics into a "greasy" stereotype, too. Not all mechanics are greasy, because some don't do real work. These mechanics work as "service managers" or in "marketing".
We all should have empathy towards the mechanics we see out there, who listen to cranky people like us, whining and complaining about our car problems. So, the next time you see a mechanic, shake his or HER hand (even though its greasy) and thank them for putting up with us, and charging such reasonable amounts of money for the magic they perform on our wonderful treasures, our Maximas.
I posted this just to get to 300
Old Jan 3, 2002 | 11:04 PM
Craig Mack's Avatar
Re: Re: Hmm, shall I install the Y myself or pay a greasy mechanic ? Help please.
I ban you from my thread, PW bish.
Old Jan 3, 2002 | 11:05 PM
Craig Mack's Avatar
Dont you mean 'water' proof ?
Old Jan 3, 2002 | 11:16 PM
emax02's Avatar
100 words perminute aint easy
Old Jan 4, 2002 | 05:44 AM
2DMax's Avatar
If I got hot and sweaty, would you watch me Sprint ?!
cruce91
Sep 20, 2015 10:23 AM
305head
Aug 26, 2015 09:03 PM
kirkhilles
Aug 8, 2015 10:53 AM
