Dyno plot comparison for Franken Intake on 2k2 Max (for easier viewability)
Old Jan 5, 2002 | 06:03 PM
soundmike's Avatar
Very sound, Mike
Taken from MattC's post here. I took both graphs and tried lining them up according to the RPM range.
The graphs seemed to have been scanned differently thus the reason it won't line up directly without some minor modification (e.g. moving the graphs until the rpm range lines up)
It's not a very accurate plot of both graphs but it should give you an idea of how much HP/Torque is gained/lost at a certain RPM range.
I did not resize MattC's graphs as that would just screw up the whole graph.
You can
view the overlay of the graphs here
For your reference, i have lined up the graphs on the 2.5, 4.5 and 6.0k RPM range so the overlays should be accurate at those points.
Old Jan 5, 2002 | 06:36 PM
Stereodude's Avatar
Here, I fixed it so they overlay better.
http://stereo.d2g.com:900/frankentake.jpg
Stereodude
Old Jan 5, 2002 | 06:52 PM
soundmike's Avatar
Very sound, Mike
Hey, i'm curious. How did you get both graphs to line up properly? Without re-scaling either one of them the RPM's don't line up except at one point or unless you adjust each rpm range accordingly.
Thanks.
Stereodude
Old Jan 5, 2002 | 07:02 PM
Stereodude's Avatar
Thanks.
Simple, I only stretched the horizontal direction so that the right RPM range spanned the same number of pixels as the other. Then I laid them on top of each other and changed the colors.
Stereodude
Old Jan 5, 2002 | 07:18 PM
soundmike's Avatar
Very sound, Mike
Hmm... i did that initially, but wouldn't that make the graph "stretched" as well?
Hmm... then again, they do seem to line up perfectly
Stereodude
Old Jan 5, 2002 | 07:41 PM
deezo's Avatar
That's madd confusing to look at(long day at work). Is more power gained or lost overall/
Old Jan 5, 2002 | 07:54 PM
Stereodude's Avatar
Gained
Stereodude
Old Jan 5, 2002 | 07:56 PM
deezo's Avatar
Gained
Stereodude
Gained means good.
Old Jan 5, 2002 | 08:06 PM
MardiGrasMax's Avatar
Real gains on the intake start at ~5200 and go till you cut it off.
Looks pretty standard for a HAI.
Old Jan 5, 2002 | 08:14 PM
deezo's Avatar
I looked at the charts separately and I must say that the torque curve looks very impressive with the intake. It looks like it really doesn't want to drop.
Old Jan 5, 2002 | 09:55 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
ya it's a noticable difference. on the way there with my stock air box in it was a long ride. no noise, less power
Old Jan 7, 2002 | 04:15 PM
ru4real's Avatar
Is that drop from 4300 to 4700 typical of other HAIs?
How much does NE Dyno charge?
Steve, you got PM.
Old Jan 7, 2002 | 04:27 PM
Greg's2kGLE's Avatar
It gained a hell of a lot on the low end, but it drops off more than stock on the high end. I thought it was supposed to be the other way around???
cruce91
Sep 20, 2015 10:23 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
