PCV Valve replacement from Jiffy Lube?
Old Nov 10, 2000 | 01:06 PM
hokiemax's Avatar
hi all. I need to change my pcv valve but I know it's a pain in the *** and the dealer wants at least 70 bucks to change it. But Jiffy Lube does it for like $12 bucks. Is it safe to let them change your PCV valve? I know they dont change PCV valves all that often and I'm kind of reluctant to let them do it on mine.
Any opinions?
Old Nov 10, 2000 | 01:13 PM
ZuMBLe's Avatar
Do it yourself. Its not that bad. Need a flathead screw driver. And needle nose pliars. But if you want to risk and and spend 12 dollars. Then its a easy job for the jiffy lube guys. But you can only be sure if it was done right if you do it yourself.
ZuM
Old Nov 10, 2000 | 01:31 PM
Synki's Avatar
Your better off doin it yourself. On the 95-2k Max, we put that as N/A b/c we arent willing to go through the trouble. Besides that, we never carried it. I werked p/t at Jiffy Lube for about a year and just quit. They are all morons there... at least here in NJ.
Old Nov 10, 2000 | 02:37 PM
humaras's Avatar
Next time
We have one of these meets--if and when I see DanNY, he said he was going to do it for me. heheh
Zumble--you wnat to take a stab at my PCV valve? haha.
:bounce:
how's the car running. I haven't driven mine in sometime now.
Old Nov 10, 2000 | 11:10 PM
ZuMBLe's Avatar
Re: Next time
Do it yourself.. Its for your own good!! =P Screw driver.. pliars.. =P Remove brakets in the way.. =) 15 minute job. Do it this weekend! Thats your assignment.. =)
My car runs fine. BUT! I did a drain and flush the other day. I took out about 5 quarts of ATF. I've put in at least 6!! And it was still reading low when I got home today. I put more in and I'm going to check the level after some driving tomorrow. Weird.
ZuM
:bounce:
Old Nov 11, 2000 | 06:03 AM
humaras's Avatar
assignment
Zum--you hurt me *sniff*
j/k
Yes, I know it is for my own good---and you are right--I must take a stab at this myself--so I will try it this weekend and report back--however, if it does rain--then it will have to wait for next weekend.
btw, it does sound weird--you took out less but you have to add more. Did you check the dipstick before draining and refilling? what kind of tranny fluid are you putting in there? Mobil or the stock stuff--what the heck brand of ATF does Nissan dealers use when they do the drain and refill?
hope you got an exciting weekend lined up--I am going back to sleep
ZuM
:bounce:
Old Nov 11, 2000 | 06:06 AM
got rice?'s Avatar
ZuM
Also, spend the $10-14 for a GENUINE NIssan PCV valve - don't buy those cheapo ones for $2. Also replace the rubber hosing at the same time.
Old Nov 11, 2000 | 09:49 AM
ZuMBLe's Avatar
Re: assignment
So far its not really raining. Doesn't look it. But I just woke up. =) So I dono. Yeah, it will take you only a few min to do the PCV. I'm glad I went and checked it the other day. Now next time when I replace it. It will be a snap. Just like the tranny fluid. I don't have to rely on anyone to do it anymore. I'm gonna change my coolant today maybe. Anyways. I put in synthetic Mobil ATF. I've checked the ATF levels before when I installed my tranny cooler. And they were okay. The nissan dealers may have nissan brand ATF. Just like how honda has Honda brand MTF.
ZuM
j/k
[/I][/QUOTE] [/I][/QUOTE]
Old Sep 1, 2003 | 04:17 PM
venompwr2's Avatar
ok well I dont know about you guys, but my pCV valve wasnt quite so easy to do, especially w/ the FSTB in the way. I started it, and had to stop because I got a giant gash in my finger and blood all over the engine, never did change it yet- 3 months later.
Old Sep 2, 2003 | 12:37 AM
maximaseefu's Avatar
the pcv valve is easy as hell to change. couldn't imagine paying some monkey 70 bux to change it. at least give it a try. compared to the fuel filter, it's like heaven.
Old Sep 2, 2003 | 01:13 PM
venompwr2's Avatar
see now I"ve had the opposite, PCV doesnt want to come out of mine, and I did the fuel filter in 5 minutes.
Old Sep 2, 2003 | 03:38 PM
eclypsecl's Avatar
where's the pcv valve :-X
Old Sep 2, 2003 | 04:05 PM
ivelweyz
PCV costs $3 and takes 5 minutes. I'm sorry but if you can't change a PCV you really shouldn't bother with trying anything else...
Old Sep 2, 2003 | 07:19 PM
that is strange. the first time i did it the hardest part of changing pcv was finding the sucker.
CorollaULEV
30
Aug 9, 2021 08:11 PM
lowpost99
22
Sep 2, 2015 04:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
