Engine startup rattle at hot weather?
Old Jul 24, 2012 | 03:13 PM
L36's Avatar
L36
Hello.
I have a VQ35 and it seems that i get a rattle, more like a knock when i start up. Ive noticed this happen when its hot outside (100+ F) and the engine is warm. Sound like when you change the oil and put a new filter in and you get that initial knocking rattle noise for a fraction of a second while the oil pressure builds up.
Anyone else run into such issue before? Can't be the tensioners/chains, all replaced by me. Using mobile 1 5W-30 synthetic. Have like 1K miles on the oil. Oil level at full.
Il try to catch a video of this.
Old Jul 24, 2012 | 05:12 PM
asand1's Avatar
Switch to 10W/40 for summer.
Old Jul 24, 2012 | 07:27 PM
L36's Avatar
L36
Yeah i might do that if this keeps happening.
Old Jul 24, 2012 | 07:28 PM
chrome91's Avatar
sounds like timing chain rattle, try swapping to a heavier weight oil
Old Jul 24, 2012 | 07:34 PM
sascuderi's Avatar
I have the same thing this summer on my 2000 I30. I posted it a few weeks ago over at the 5th gen section, but did not get a single response.
I have also been using the same oil as you but have been using it for years and never had this issue before.
After reading around the web, some suggested (other cars and forums) that it could be a fuel delivery issue or fuel leaking from the injectors when off.
Other sites have discussed all types of rough starts that have been cured with seafoam
So, three days ago I added 2 bottles of Seafoam into a full tank of gas, and so far the issue has not happened. But, I need a few more days to be sure.
Old Jul 24, 2012 | 08:09 PM
L36's Avatar
L36
Nope, everything has been replaced when regarding timing chain components.
Ive already ran some seafoam in the tank couple months ago, but it was only 1/3 of the bottle.
Old Jul 25, 2012 | 06:52 PM
sascuderi's Avatar
So far so good after putting 2 bottles in a full tank at the same time, but will have a better idea after this weekend if this is the fix
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
bennuss
Sep 11, 2015 05:55 AM
