Starter groaning, hard to start
Old Nov 18, 2012 | 01:03 AM
mattyd's Avatar
I've been having a problem starting recently. The starter on my 93 SE groans and gives a slow turn sometimes, but it cranks well enough it seems. I tested the old battery and it dropped to 7v during load, so I replaced that. however the noise still persists. I also need to hold the ignition down for a long time, even after there has been some ignition in the cylinders and the car is sort of running.
I've done a voltage drop test to the starter and it seems to be fine. Am I going to need to replace this thing?
Old Nov 18, 2012 | 02:51 PM
asand1's Avatar
I would try disassembling the starter and thoroughly cleaning greasing it. check the brushes while you are in there.
Old Nov 25, 2012 | 10:43 PM
mattyd's Avatar
had the starter bench tested. sounds like the bearings are shot(?) -- metal on metal scraping as the gear turns. For only $60 to replace with a new one I'll just be doing that.
Old Nov 30, 2012 | 06:23 PM
T_Behr904's Avatar
Yep sounds like the starter. I've had my car for about 2 years and have replaced it twice. No more 1 year warranties for me. I picked up my latest starter from O'Reilly's with a lifetime warranty.
Old Dec 2, 2012 | 02:36 PM
asand1's Avatar
Probably just the planetary gears needing lube. I would re-grease a proven starter every time, over buying an unproven aftermarket or reman starter. Hell, $2 worth of grease, or $90+ for a starter that may be worse than your original?
97_GXE
Sep 15, 2015 06:47 AM
rnb754
Sep 14, 2015 11:39 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
jwright36
Sep 8, 2015 11:45 AM
trungg86
Sep 4, 2015 04:58 AM
