Fully N/A modded 4th gen 5-speed loses to 4th gen AUTO....
Old Jan 10, 2002 | 10:52 AM
  #41
Sprint's Avatar
Originally posted by PhatGuy
Oh I thought he was an auto.
Synki is talking about someone totally diffrent.. not any of the 3 guys from Chicago...
Old Jan 10, 2002 | 10:57 AM
  #42
PhatGuy
Originally posted by SprintMax
on the street brian use to be faster.. but he says he is only pulling 1 car now.. MAX2000JP as far as i know.. thats the best run i could find with the search function...
Hmmmm I read in the first post of this thread:
"So my car is pretty much back up to speed....not quite as quick as it used to be. I ran MAX2000JP(5th gen 5-speed, intake and y-pipe) today from 40-100 and we were pretty much even. (I used to pull on him about a car.) "
Old Jan 10, 2002 | 10:59 AM
  #43
Sprint's Avatar
sorry for the mis-information
Old Jan 10, 2002 | 11:02 AM
  #44
PhatGuy
The King of New York stands corrected!
Old Jan 10, 2002 | 11:04 AM
  #45
clee130's Avatar
Sprint isn't from NY.
Old Jan 10, 2002 | 11:06 AM
  #46
Sprint's Avatar
doesn't mean i can't be king
  #47
PhatGuy
I know that but he still thinks he is the King of New York let alone the tri state area!
NYC probably isn't good enough for the elite individual and his god like chariot!
Old Jan 10, 2002 | 11:09 AM
  #48
redmaxpa007's Avatar
i SeE what you did therE
NYC probably isn't good enough for the elite individual!
stop it..
he will think he is the KING OF THE EAST COAST soon
  #49
Sprint's Avatar
I cover more states than 3 .. NY/NJ/PA/CT/MA/RI/NH
just call me KOTNE .. King of the North East
Old Jan 10, 2002 | 11:13 AM
  #50
SEE!!!
i told JoO!!!
Old Jan 10, 2002 | 11:15 AM
  #51
Sprint's Avatar
Originally posted by redmaxpa007
stop it..
nah.. not when you have bags and nismo2020 down in ATL.. and eben in DC.. i will just be a good boy and stick to the North East
Old Jan 10, 2002 | 12:08 PM
  #52
jdmmax's Avatar
i have a 99 se-l but i have cali emissions
yeah cali emissions sucks @ss.
Old Jan 10, 2002 | 12:55 PM
  #53
Nealoc187's Avatar
SLOW
Brian and I will do some runs this weekend to get things sorted out. When I raced Szymon (max7) on the highway, the day I got my Y-pipe on, he pulled about 12 inches from 60-90 or so. That was before his UDP though.
Old Jan 10, 2002 | 01:39 PM
  #54
Dave B's Avatar
Not DAVEB the parts guy
Like I've said before, a dyno is tuning tool. You tune your car on the dyno, that's all. It's not there to compare your "hard numbers" to someone else's "hard numbers" fourteen states away. All dynos read a little differently therefore it is essential to dyno on the same machine to gauge performance increases/decreases.
From what I've seen on this site, on average, a 4th gen 5 speed with a Y-pipe, intake, and catback puts down 175-180fwhp and 185-190fwtq. Then you've got these very few 4th gens, people refer to as "factory freaks", that are cranking out 185-195fwhp and 195-205fwtq. I find it nearly impossible to believe that one 4th gen can come off the assembly line with 10+fwhp and 10+fwtq just because it's the luck of the draw. The VQ is put together with extremely high tolerances therefore the power difference between motors should be very minimal. Where do people really think this added power comes from? It can't be better castings in the intake manifold or exhaust manifolds because it's been shown that extrube honing either of these parts does nothing. The heads can't be any different unless some random worker, just for fun, decides to open up the intake and exhaust ports. It's not the cams. What else could it be?
The "Factory Freak" Maximas also seem to perform no better than the "factory average" Maximas. A 10fwhp and 10fwtq advantage is like adding another Y-pipe. If these Maximas were truely Factory freaks, they'd run freakishly. The truth is, they don't.
The 4th gen Maxima's that have run 14.2-14.4s aren't Factory Freaks. They are well driven cars on relatively decent tracks and under good conditions. ANY Maxima that is able to hit 94mph trap speeds is more than capable of hitting a 14.4. It's jsut dependant on driver and conditions. For every 1mph faster in the 1/4, you can shave off another .1-.15 in et.
Dave
Old Jan 10, 2002 | 01:43 PM
  #55
Washington DC Maxima's Avatar
Damn!!
Two post today!!!
Exactly!!!
Dave
Old Jan 10, 2002 | 01:53 PM
  #56
BriGuyMax's Avatar
ok...I think I have sorted things out a little bit.
First of all, I recently installed my rubber floor mats in my car for the winter. I noticed today that the driver one gets itself up under the accelerator pedal and doesn't allow the pedal to go all the way to the floor. Hence not allowing my car to achieve full throttle That's issue number 1
Issue number 2:
A few monthes ago we tried to re-set Adam's (Chi99Limited) ECU in his car...but found that there is NO SCREW on the ECU...in fact the ecu looks different from mine. As far as I know, all stock 4th gen ECUs have that little screw. Is there anyway that he could have gotten some aftermarket ECU with his car and not known about it. (he got his car used and it already had a few mods on it) I know there isn't any commercially available ECU for the 97-99 max....but who knows.....
PhatGuy - MAX2000JP ran his car with a leaky y-pipe in 90 degree heat and high humidity....so his time is not really indicitive of how fast his car really is. His y-pipe is fixed now...and he had his ECU reprogrammed by Nissan.
Old Jan 10, 2002 | 01:58 PM
  #57
Sprint's Avatar
Issue number 2:
#1 Also .. check your WOT switch for your NOS.. make sure that it is allowing you to go WOT.. when i installed my NOS.. i took the switch out too far.. and i notice that i couldn't walk my cousin's 97 5spd SE anymore after installing the NOS (not using it) till one day i met up with dmbmaxima aka Steve at the pike and we are comparing engine bay's and he says to me.. dude.. your switch is out too far.. after he adjusted it.. i raced my cousin again and i could walk him again..
#2 For his ECU not to have a screw on it.. it would have to be a stand alone ECU.. their are no stand alone ECU's out for the 99 at this time.. not even reprogrammed stock ECU's.. so i am not sure.. i would ask another SE-L owner to double check to see if they have the screw also.. and please please.. get that car dyno'd ASAP..
Old Jan 10, 2002 | 02:02 PM
  #58
Y2KevSE's Avatar
Rice Boy in Denial =)
Issue number 2:
Sounds like a 5th gen ECU.
Old Jan 10, 2002 | 02:44 PM
  #59
BriGuyMax's Avatar
I already checked my WOT switch...it's fine...I asked talked to Szymon (Max7) today..and he has the screw on his 99 SE-L just like my 97 does....so who knows....maybe there IS a stand alone ECU for 4th gens...and we just don't know it....
Old Jan 10, 2002 | 02:49 PM
  #60
ru4real's Avatar
ME and VT aren't worthwhile to include?
Old Jan 10, 2002 | 02:56 PM
  #61
gtr_rider's Avatar
192.168.1.1
can you do that?
Old Jan 10, 2002 | 03:59 PM
  #62
UMD_MaxSE's Avatar
Got Bent?
Originally posted by gtr_rider
can you do that?
apparently, the '99 models shared quite a bit of parts with the 5th gen.
Old Jan 10, 2002 | 04:02 PM
  #63
Sprint's Avatar
no thats partially canadia
Old Jan 10, 2002 | 04:14 PM
  #64
CHI99Limited's Avatar
Originally posted by max7
Second I want a crack at this guy just not on the street, because for a Wheaton cop got me for speeding this morning so I refuse to go fast on the road for some time now. Hey let's take everyone to the track and I'll find a way to beat him. Better yet lets get Neal to race him. The way Neal get's things done none of us have a chance. I'll call you soon as I get cought up with my crap. I hate going to school and working, too much stuff to do! Take care!
I dont think you can handle a race with me . Yea i dont know what the deal with my car is, its too fast for what it is. A while back i posted about klling my buddies TL-S , and people didnt believe this. What i did to the Acura and Brian's care arent supposed to happen in an auto with my mods. During the summer i am gonna for sure take my car and run the 1/4 and possibly dyno the car. I am supposed to race my friends 97 auto m3 this weekend, if i beeat this i think it is safe to say i have a factory freak.
Old Jan 10, 2002 | 04:17 PM
  #65
Cumalot's Avatar
Do you have any stickers on your car? If you do, you know stickers will give you awesome hp! j/k...
I'm impressed to say the least. I'm glad that a fellow automagic can land the smackdown like you did because I know I couldn't.
Old Jan 10, 2002 | 04:23 PM
  #66
Sprint's Avatar
here is a theory for you.. which only a dyno can prove..
the 5th Gen ECU has remapped fuel maps and advanced timing.. so that would be like a JWT/UPRD/STILLEN ECU for a 4th Gen..
so maybe he has a 5th ECU.. which would make him have more than 190 hp stock.. hmmmm.. just a theory..
Old Jan 10, 2002 | 04:35 PM
  #67
I think my car was made very late in the model year. I believe it mas made in May of 99....do you think they may have started using a 5th gen ecu? I don't think the guy i bought it from was into performance, he just had the aero kit and muffler put on. I am gonna have to take this thing ad get a dyno one day. Maybe we can get a gruop deal going one day, Brian?
Old Jan 10, 2002 | 04:41 PM
  #68
Sprint's Avatar
yeah Kev said the 5th Gen's have no screw.. so it might be..
Old Jan 10, 2002 | 04:59 PM
  #69
Maximamike's Avatar
I think its funny you guys think stand alone ECU's are dependant on the year of your car. LOL
Old Jan 10, 2002 | 05:33 PM
  #70
black019's Avatar
explain
Old Jan 10, 2002 | 05:34 PM
  #71
Sprint's Avatar
i meant reprogammed ECU for the 99 .. i know you can get one of those $1000 Stand alone ECU's
Old Jan 10, 2002 | 06:22 PM
  #72
DaEnigma's Avatar
Now I am gonna just have to look at my ECU... to see if there is a screw...
Old Jan 10, 2002 | 06:29 PM
  #73
Maximamike's Avatar
Originally posted by black019
explain
Key words in Stand Alone ECU are Stand Alone. This means it doesn't require your factory ECU but may or may not use the sensors that the factory one did. You can put a stand alone on everything from a formula one car to your ride on lawn mower..
Old Jan 10, 2002 | 07:58 PM
  #74
BriGuyMax's Avatar
ok...so after what I experienced tonight on the way home from work....either my rubber mat under my gas pedal REALLY hurt me yesterday, or his car is truely a factory freak. I ran a 320hp (one with the projector headlights) 3000GT VR-4 from a 30 roll tonight....and he ONLY pulled a half car to 90mph....this is after I cut a section out of my floor mat today Something tells me that Chi99Limited is NOT going to beat a VR-4 from a roll....
Old Jan 10, 2002 | 08:03 PM
  #75
I dont know....well have to do it again this weekend. I really dont think that the floor mat had much to do wit it b/c when i saw u and my bro run I would have spanked his car based on what i did to you.
Old Jan 10, 2002 | 08:08 PM
  #76
Cumalot's Avatar
Only way to find out is:
BriGuyMax vs. CHI99Limited Round 2.
Old Jan 10, 2002 | 11:46 PM
  #77
Nealoc187's Avatar
SLOW
I was under the impression that 99 ECUs did not have screws in them. Maybe thats only true for LATE 99 models or something. There was a post about this the other day. Similar to some of the VERY early 95s being OBD-I vs all others being OBD-II? Thats my theory.
Old Jan 11, 2002 | 04:44 AM
  #78
99.5 maximas have a lot of parts from a 2000.
i have a screw in my ecu.. my car is early 99 actually ...12/98
so the 5th gen ecu is a possible theory.. hmmm i wonder if that will work will all forth gens...
who know a junk yard where we can get an ecu?
Old Jan 11, 2002 | 12:03 PM
  #79
Ruckus's Avatar
HAHA i guess that means i'm still the king of DELAWARE!!!
...or does delaware really count?
Old Jan 11, 2002 | 08:17 PM
  #80
dashingMax's Avatar
Originally posted by Cumalot
You ever raced the 99SE-L auto before this time? What was the result if you did race him?
Very weird, I can't come up with an explanation. You sure all he had was an intake and ypipe? He must be one of the fastest NA auto if he is as fast as you say he is.
That is why they call 'em SE-L. "Limited" edition. Secret formula for some serious ***-whopping.
Mine's even faster. 1999 SE-L FIVE-SPEED
