New Wiring Harness needed?
Old Jan 12, 2002 | 05:06 PM
Reed94SE's Avatar
I ordered these 9004 Hiper High Intensity Discharge HID xenon bulbs from ebay. they say that they don't over heat and that the wiring is protected, but everything else that I've heard on this site mentions upgrading the wiring harness. will these bulbs burn out my stock wiring? thanks.
here is some info about the bulbs. They were $15, which might be a bad thing.
--A pair of 9004 Hiper High Intensity Discharge HID xenon bulbs---
Description:
Guarantee BRAND NEW
No reserve
Super white plasma xenon bulbs with bluish tint by Hiper
High quality xenon charged HID lamp, 85/80W > 130/100W (=50% brighter) with no extra current draw
No overheat (wiring is protected)
Quick and easy to install (plug and play), no modification needed
100% street legal
Old Jan 12, 2002 | 05:20 PM
ereet's Avatar
Re: New Wiring Harness needed?
As far as I know Hiper bulbs aren't DOT approved which means they're for off road use only.
I use Hiper bulbs, and they've melted my harnesses once already (tend to go every 2-4 months) .. Get an upgraded harness, or make one yourself (ie, upgrading the power & ground wiring to your current harnesses.)
Old Jan 12, 2002 | 07:40 PM
Ravq's Avatar
I recommend getting the harness to save you a lot of trouble in case it does melt your stock harness or socket. At least with the upgrade harness you can use overwattage bulbs safer than without it. You can get them here:
www.autodynamic.com
www.suvlights.com
Old Jan 13, 2002 | 12:33 AM
95emeraldgxe's Avatar
burnt plastic is not exactly the most pleasant smell in the world....spend 5 bucks and play it safe
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
maximaham
Aug 7, 2015 01:11 PM
