dip stick mod.
Old Apr 20, 2013 | 03:45 PM
uptownsamcv's Avatar
dip stick mod.
inwas wondering if anyone ever tried modding the dip stick on a a VQ for better reading?
I have my upper pan off and after examining it I see that the front of the dipstick rubs pretty much wiping off the oil on there. I was thinking of getting a small metal shield ( piece of another dipstick ) welded to the hump on the dipstick and down to the tip. that was when you pill the dipstick out it will just tub oil off the shield...
any thoughts?
Old Apr 20, 2013 | 03:49 PM
BlackThornDemon's Avatar
That's why it has dimples?
Old Apr 20, 2013 | 03:50 PM
theblackone3.5's Avatar
complete waste of time!!!
Old Apr 20, 2013 | 03:53 PM
the dimples dont work at all.
Old Apr 20, 2013 | 03:56 PM
wont take but a few minutes to cut a junkyard dipstick and weld a piece of it to the tip of the dipstick.
it works on my. it has oil, yeah!!!!!
Old Apr 20, 2013 | 04:03 PM
Old Apr 20, 2013 | 06:48 PM
Leo_Koneval's Avatar
Oh, so that is why the dipstick does not work at all with the engine on? Because if i check the dipstick with the engine running or recently running, the dip stick would be coated with oil from top to bottom whenever i put it in and pull it out.
I guess a shield to protect the dipstick from rubbing against the oil covered surfaces would be a good idea!
Old Apr 20, 2013 | 11:27 PM
you only check the engine oil when the motor is off. most engines have the oil return pasage away from the dipstick so you can just shut the motor off clean the dipstick and see the oil level. i can see from my friends 350z heads in the garage that the oil returns are under the cam gears and theres no oil return passage on deck of the block, its all within the timing chain cover.
Old Apr 20, 2013 | 11:48 PM
max ride 41's Avatar
it's supposed to be cold too man, only trans gets checked while the motor is running and warmed up to running temp. get an fsm, it'll tell you all about how nissan put the car together and how to fix.
REDinLV
Aug 15, 2024 12:30 AM
05RLS2
Nov 7, 2016 05:52 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Redfox
Sep 28, 2015 10:41 AM
adamgalazka
Sep 8, 2015 01:27 PM
