Removing tint?
Old Jan 16, 2002 | 02:43 PM
BillN
Removing tint?
My car got broken into last weekend and I got the window replaced but the problem is that the driver side window is still tinted. I am getting all of the windows re-done in the spring but for the time being I would like to at least have the tint off the driver's side. Btw, it has been on the car for about three years. Does anyone know how to remove tint?
Old Jan 16, 2002 | 02:49 PM
Mishmosh's Avatar
Re: Removing tint?
Peel off as much of the tint as you can. Spray the window liberally with ammonia and cover for 10-15 with cellophane wrap to allow the old adhesive to soften. Then, get a flat edge razor blade (stainless steel) and scrap off the gummy adhesive. Any difficult spots need to be re-sprayed and scraped off. To be thorough, it is best to remove the door panel.
Old Jan 16, 2002 | 03:34 PM
Chunger's Avatar
My other car is a Hybrid
You can soak/bake the whole piece a few hours in the sun before peeling... with luck, most of it will come off in a large sheet with the adhesive backing as well.
Old Jan 16, 2002 | 08:49 PM
BillN
Bake?
What do you mean by bake? Should I use a heat gun or something?
Old Jan 16, 2002 | 09:04 PM
finny's Avatar
anything but the rear window with refrosters just take as much off as ya can then hit it with the razor blades. itll take care of it
Old Jan 17, 2002 | 02:26 AM
BigDogJonx's Avatar
The pro I took my car to removed the tint with nothing but a heat gun. He just heats the outside of the glass and just slowly peels off the tint on the other side.
He said he does this method, because as he is peeling the tint off, there is no sticky residue or glue left behind. He can then just straight clean the window and tint it again.
I have done this method myself, and believe it is the best method, just takes time. I never like the amonia or orange cleaner method with a sos pad. Too much pain.
Dixit
Old Jan 17, 2002 | 06:12 AM
vitas's Avatar
your gonna need alot of time and windex and a razor.
Old Jan 17, 2002 | 07:12 AM
HondaKiller718's Avatar
Or you can just leave it there and be original
Old Jan 17, 2002 | 03:16 PM
BillN
Oringinal
Is that Original or just plain old tacky??
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
