LED dome light
Old Mar 8, 2014 | 08:52 PM
ac max 92's Avatar
LED dome light
I noticed on my winter car when putting an LED bulb in the dome light it stays on even with the doors closed. Put the halogen back in and works the way it should light on when doors open light off when doors closed. Anyone ever have this issue or know the fix for it? I tried using 2 different LED's and still had the same thing happen?
Old Mar 9, 2014 | 11:23 AM
DAlastDON's Avatar
If you are talking about the LED being very dimly lit. Mine have done it since i installed them in 2008 and caused no issues. I always assumed that it was a small voltage leakage from the battery saver circuit. Not enough to make a regular light bulb do anything but just enough to light up an LED.
Old Mar 9, 2014 | 12:35 PM
Leo_Koneval's Avatar
It does not happen in my 4th gen, but I learned that newer cars have a thingy that makes the dome light slowly dim when you close the door. With a standard halogen bulb it draws enough power to drain that thingy and turn off completely; while LEDs don't drain enough power to use up that left over electricity completely so it keeps going.
Not too sure if it is true, but that is what I dug up while doing research a while ago.
Old Mar 9, 2014 | 03:19 PM
ac max 92's Avatar
The LED is nice and bright but just stays on unless i phsically turn the dome light to the off position.
MaxLife17
Jun 27, 2019 01:37 PM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
