indiglo gauges installation
Old Jan 21, 2002 | 12:33 PM
MrBlank's Avatar
I bought my indiglogauges for like 35 off ebay but I have no idea how to put them in. I called my neighborhood fix it guy and he said he would put them in for $60. Is that too much? I really would have no clue on how to put them in even with instructions but I aint trying to get RIPPED.
Old Jan 21, 2002 | 02:27 PM
mzmtg's Avatar
Minister of Silly Walks
Find instructions on www.maximadriver.com
You can do it yourself easy.
Old Jan 21, 2002 | 03:48 PM
95emeraldgxe's Avatar
installing these guages are very simple......dont give him the money!!!!! 60 dollars is way too much.....where do u live?? i'll do it for like 10 bucks (and i still feel like i'm ripping you off) all you have to do is take out the guage cluster and then put the guages on over the needles and then maybe use a small amount of double sided tape to hold it in....... for detailed instructions click this link .... http://www.seas.ucla.edu/%7Echeston/...loinstall.html
Old Jan 21, 2002 | 04:20 PM
mzmtg's Avatar
Thank you for posting the same link I did.
Do you ever type in complete sentences, with correct grammar?
Old Jan 21, 2002 | 11:33 PM
JoesMAX's Avatar
its easy to put them in... but to get them to stay down without the needles sticking, now thats a different story. the screws that hold down the stock faces get taken out and there arent holes in the indiglo's.
Old Jan 22, 2002 | 05:01 AM
DCmax's Avatar
Re: indiglo gauges installation
Yeah $60 is still a rip off not to mention the satisfaction and experience youll gain from doing it yourself. FYI: most places in the DC Area do gauges for prices in upwards of $150-$200, now THAT is crazy.
Old Jan 22, 2002 | 09:21 AM
MrBlank's Avatar
Aight its done but now none of the sticks work. They get stuck all the time......grrrrrrrrrr
Anyone else have this problem?how do you fix it?
Old Jan 22, 2002 | 09:34 AM
DCmax's Avatar
You just need to make sure the overlays are laying as flat as possible. Very thin double sided tape works as well as glue stick. A lot of people have this problem, it's just a function of the needle not being able to rotate as freely due to slight tension from the new gauges.
Old Jan 22, 2002 | 09:50 AM
MrBlank's Avatar
I used a glue gun to keep it down.Dont know how much flatter it can get
Old Jan 22, 2002 | 10:23 AM
DCmax's Avatar
Where did you glue? It needs it most towards the center of the gauge.
Also you may try to gently push down on the needles. The needles werent working on a friend's Prelude after we put in indiglo gauges but after pushing down on each needle, even when we thought it wasnt doing much, worked.
Old Jan 22, 2002 | 02:35 PM
JoesMAX's Avatar
crazy glue works great because it dries fast and you can hold it down tight to the old faces while its drying... if i ever take them out i will get white overlays because the black faces will be messed up from the crazy glue
Old Jan 22, 2002 | 03:10 PM
Sway1331's Avatar
why do the indiglo 5/6 color gauges on custommaxima say only for the se model? is it because of the color of the needles or am i way off and missing the point.
Old Jan 22, 2002 | 04:04 PM
darksands's Avatar
Indiglo
I put the 5-6 color one in my car but i dont use it that much. The average lifespan of indiglo gauges is like 2 years. Something in the box burns out so I rarely use it. I think it still looks kool without it on. Be carful when putting it on. The needles could get messed up. Good luck.
Old Jan 22, 2002 | 05:20 PM
JoesMAX's Avatar
Re: Indiglo
how do you not use it? where did you connect the power source to a switch? with mine i have them so when i turn on my parking lights they come on... did you leave the bulbs in the gauges then? i only left the ones by the odometers
Old Jan 22, 2002 | 06:54 PM
JAIMECBR900's Avatar
I installed mine w/o glue. It was very difficult, but if you're careful you can take an awl and gently make a pilot hole for the factory screws to go back in. This way none of my needles gets stuck at all, except the temp gauge just before it gets to the middle. Reason is because on that gauge, the factory screw would have gone on top of the contact strip, so I had to position it a hair off and so it doesn't lay as flat in the middle. But all in all, the gauges work perfectly.
Old Jan 22, 2002 | 07:22 PM
JoesMAX's Avatar
it doesnt mess up the indiglo if you make holes in it? i was gonna do that but they i was thinking wait, i dont want to mess anything up... they should have just made holes in them in the first place
Old Jan 22, 2002 | 08:40 PM
It didn't on mine. These were the first I ever installed, so now that I think about it it probably would of been much easier to use some kind of glue. Oh well, you live and learn. Really, mine are working fine and no sticking at all, except for the above mentioned temp gauge dilema.
cruce91
Sep 20, 2015 10:23 AM
97_GXE
20
Sep 17, 2015 08:12 PM
BrandonCause
Sep 14, 2015 10:41 PM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
