liquid line & suction line?
Old Jan 23, 2002 | 08:51 PM
easy
The prices in the carpart.com is
A/C Refrigerant Filter, Suction Line With Hose No.12 5/8" ID; VIN H GXE Listing 30
A/C Refrigerant Filter, Liquid Line With Hose No.6 5/16" ID; VIN H GXE Listing 45
what is the diff between suction and liquid?
what are the No.12 & No.6 stand for?
thanks.
I am a new hand, want to change the filter myselt, is that difficult?
what is the accumulator of the a/c? the same as air filter? also needs scheduled maintenance?
Old Jan 23, 2002 | 09:01 PM
RedMax95's Avatar
Re: liquid line & suction line?
thanks.
suction hoses take in air, also called vacuum hoses, liquid transports, well, liquid such as oil, gas, radiator fluid, etc.
Old Jan 23, 2002 | 11:30 PM
eric93SE's Avatar
The suction line is the larger (probably the no.12) this line has the gasses returned to the compressor. The liquid line (small hose) sends the liquid coolant to the expansion valve where the gasses are able to expand and cool.
It's good that you are replacing the reciever dryer/accumulator...but, Usually they last quit a long time. I dont reccomend you doing this b/c to do it properly you need a good vacuum pump and guages to remove all the moisture out of the system if you want to have full performance out of the system. Keeping moisture out is critical.
Old Jan 24, 2002 | 07:27 AM
njmaxseltd's Avatar
Why would you be replaceing these items anyhow? They should last the life of your car unless there damaged or the system is opened up.
If the system is opened up you need to have it pumped dry with a vacuume as eric mentioned. Let a shop do this job. A/C systems do require some special tools. Refrigerent is under high pressure and isn't so easy to work with.
Old Jan 24, 2002 | 12:44 PM
sinewave's Avatar
Here's what you will need to change these filters.
Recovery system - $1500
Vacuum pump - $600
gauges - $100
One year at refrigeration repair school
EPA approved licenses and certifications
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
doctorpullit
Dec 12, 2015 09:39 AM
Taino14
Sep 24, 2015 02:51 PM
