vq35de swap
Old Oct 26, 2015 | 01:11 PM
Frank Fillman's Avatar
vq35de swap
I own a 2004 nissan altima V6 with a vq35de can i put a 2012 vq35de in my 2004?
Old Oct 26, 2015 | 03:30 PM
george__'s Avatar
Research the gen 5.7 swap
There's a facebook group for that and email voltagedrop SuraTT guy (voltagedrop.net).
Old Oct 26, 2015 | 04:03 PM
??? 5.7 ???? i dont get it tell me more
Old Oct 27, 2015 | 01:54 AM
Cotozic's Avatar
In the case of Maximas, 5.7 refers to the 5th gen, the 2001-2003 cars, with a 7th generation motor. We call the 2002-2003 cars the 5.5 gen because they include the VQ35DE 3.5L motor, as the 5.0 gen had the VQ30DE 3.0L motor. It's just a play on the generation numbers, or at least that's how I've understood it.
The Altima and Maxima drivetrains are similar. Do what George said. VoltageDrop has instructions and sells products to make the swap work.
Old Oct 27, 2015 | 05:33 AM
hmm
I have a 04 big body that has a 3.5 in it now but it has a knock on the bottom end and I can pick up a 2009 vs35de for 1100 will most of the wiring be the same
Old Oct 28, 2015 | 01:29 AM
Cotozic's Avatar
If I were you, I'd just look into 3.5s from your cars own model years. It will save you trouble.
Old Oct 28, 2015 | 06:59 PM
Ok thanks
Old Oct 30, 2015 | 07:12 AM
NmexMAX's Avatar
dot dot dot ...
01????
You meant 02.
And why would you want a 02/3 in your 04?
Old Nov 8, 2015 | 07:10 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by NmexMAX
01????
You meant 02.
He wouldn't have to replace the timing guides (like if he went with the direct fit models)
But, then you have potential precat damage or the regular oil burning.
Use the non EVT "HR" VQ. The only extras required for it to run perfectly are the new TB pigtail and cam signal inverter. You could just leave the EVT unplugged on a 7th gen motor, but idk if there's any long term issue with that.
Does the 04 have the new ECU? If so you could just osiris that *****.
Old Dec 8, 2015 | 03:04 PM
maxprivate's Avatar
Black Lion
5.7 Swaps are normal these days for 5th gen you just need that CAM inverter from Voltage drop. Even 4th gen guys do them for a full 3.5 route.
I just had a 3.5 2006 maxima engine put in my 4th gen, wanted to keep my super charger so I kept the 3.0 timing.
"All Out Motor works" in Hempstead NY does these swaps on the regular. He used to be a moderator on NYC Maximas, he knows these cars inside and out. tons of Maxima guys go here as well as Viper Vadim when he needs stuff done.. cool spot to hang out at.
Old Jan 23, 2016 | 10:53 AM
maxprivate's Avatar
Black Lion
I take back what i said, yea he knows his stuff but if you ever want to see your car again don't bring your car to this place.. also the customer service sucks, I had to tow my car out of there to get the attention and time it needs. My car was there over an entire year and I still don't have a running car .. Stay away.
Old Jan 24, 2016 | 06:09 AM
george__'s Avatar
I take back what i said, yea he knows his stuff but if you ever want to see your car again don't bring to this place customer service sucks, I had to tow my car out of there to get to the attention and time it needs. My car was there over an entire year and I still don't have a running car .. Stay away.
What happened?
Old Jan 24, 2016 | 07:39 AM
maxprivate's Avatar
Black Lion
Originally Posted by george__
What happened?
Bunch of false promises, never returns calls, lies, I have a blown head gaskets in a newly built engine when I was told the car was started ( which it was ) and was driven, ( but had issues with idle and ran like crap.. needed a tune of course but shouldn't have a bad coolant temp sensor ) … shall I go on? Problem was a bad coolant temp sensor so the car over heated and blew the radiator hose. But thats another story.. my point is…
I couldn't take waiting anymore to get my car back, it was there since November of 2014 and it didn't sit there because I didn't have money or was waiting for parts. The truth is; the guy just doesn't have the staff or time for project cars. He pretty much has only 1 guy that does all the heavy mechanical work.
I know other guys that have had to have their car towed out of there to get it done. Im sure others can tell you good things about this place but Im sharing my horror story so people don't get disappointed bringing their car there. So I'm now left having to pay double to have my engine pulled again, torn down, find out what the problem is and reassemble. Stay away.
Do you know this place?
Old Jan 25, 2016 | 08:16 AM
Will's Avatar
If I want to swap in the 7th engine motor for my 5.5gen with the stock 4 speed automatic transmission, how do you make the newer engine which is hooked up w a CVT compatible with my ancient slushbox?
Old Jan 25, 2016 | 08:54 AM
maxprivate's Avatar
Black Lion
Search for "Voltage Drop" online. He makes a electrical device that you would have to have wired in so that you can utilize the VCT on the 7th gen motor.
Maxxi12
Jan 13, 2016 08:38 AM
josephbolden91
Oct 29, 2015 07:02 AM
Terryw
Oct 27, 2015 12:08 AM
josephbolden91
Oct 25, 2015 09:48 PM
TitoValchev
Oct 22, 2015 05:53 PM
