Intake question
Old Jan 30, 2002 | 02:45 PM
MaxedOut97SE
Intake question
Hey everyone I've had my Stillen intake for about a year and 12k miles....should I clean it yet? How actually do I do that? I lost my info...The actual filter is K&N....
Old Jan 30, 2002 | 02:59 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Intake question
pick up a K&N recharge kit..the instruction are inside. good luck.
BTW good time to clean it if you don't see that nice pink/off pink color anymore.
Old Jan 30, 2002 | 03:04 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Re: Intake question
damn...then you should have cleaned yours a loooooooooooong time ago
Old Jan 30, 2002 | 03:08 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Intake question
joo forgot where i live? i drive down the block it's dirty again.
Old Jan 30, 2002 | 03:15 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Re: Re: Re: Intake question
i forgot
Old Jan 30, 2002 | 03:33 PM
95emeraldgxe's Avatar
general rule of thumb is u gotta clean it out once a year
Old Jan 30, 2002 | 04:45 PM
98sterlingmist's Avatar
remember also, that a dirty K&N filter will filter better than a clean K&N and allow for better flow.
Clean it anyway
Old Jan 30, 2002 | 07:08 PM
theMax's Avatar
Its fine.
You don't have to clean it until you get a dirt buildup. K&N says the filter can go 50K-100K miles without cleaning. It also says just because the red goes away, doens't mean the oil is no longer there.
...but being **** with my cars I do clean them about once a year.
Old Jan 31, 2002 | 12:15 AM
MaxedOut97SE
Thanks everyone, I really appreciate it!!!
Old Jan 31, 2002 | 11:40 AM
Eric L.'s Avatar
K&N says you don't have to clean for 50,000 miles. That's a stretch, but that's how they validate their 1 million mile warranty...i.e. the filter can last 20 cleanings. I clean mine every 10k miles or so, figure that will make the filter last 200,000 miles, much longer than the car will last.
Old Jan 31, 2002 | 12:51 PM
Badaxxima's Avatar
Clean it anyway
How's a dirty air filter gonna have better airflow than a clean one? Dirty means dust and crap has wedged it's way into the fibers and blocked possible air-travel paths. Someone please explain this to me. Blocking air flow increases the vacuum behind the filter too, which increases the chances that dust is going to get sucked through the filter and into the intake tract. Or am I completely stupid?
Old Jan 31, 2002 | 01:09 PM
theMax's Avatar
The dirt particles collected on the surface of a K&N element have very little effect on air flow because there are no small holes to clog. Particles are stopped by layers of crisscrossed cotton fibers and held in suspension by the oil. As the filter begins to collect debris, an additional form of filter action begins to take place because air must first pass through the dirt particles trapped on the surface. That means the filtration efficiency of a K&N element actually increase as the filter collects dirt. Tests have shown a K&N E-1500 filter will flow 60 percent of its maximum flow capacity after 50,000 miles of street use. And, considering a new K&N flows at least 50% more than a comparable paper element, that same filter will provide all of the air the engine needs even after 50,000 miles.
taken from
K&Ns website
Old Jan 31, 2002 | 01:12 PM
Badaxxima's Avatar
taken from
K&Ns website
Sweet, thanks.
cruce91
Sep 20, 2015 10:23 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
