Rust repair thread
Old May 15, 2017 | 10:30 PM
krismax's Avatar
Father of the 00 VI
Rust repair thread
I see a lot of threads about rust this and rust that. And if you just go to a body shop then this doesn't apply to you.
But if you want to do things,on a budget. This thread is for you.
I am not a body expert,but i will pick a few rust repair projects and go through what I have done to fix them.
I will show 4 repairs in this thread.
One radiator support fix
two rear quarter panel
third a under body spot, it appears someone thought was a jack point.
fourth rocker seem crushed by poor jacking technique
I will show the progress in 4 separate posts below for each one. If you want any pictures taken or shown. prices or anything about any one just post.
krismax's Avatar
Father of the 00 VI
Radiator support
Get a Nissan support. My lock support was also bad i replaced it.And i seam welded the new radiator support completely.(doesn't need to be done)
Untouched picture first one
second, third and forth picture, showing area i drilled spot welds out. And ground with a grinder.
I drill in areas grinder can't get. some people may want to drill out all. I prefer the grinder.
Fourth picture you can see the spot welds they put on the sides.When you drill start with a small bit .and use cutting oil and go slow. After you do that with a small bit step up to a bigger one slightly bigger than the spot weld.
Attached Thumbnails Rust repair thread-img_6120.jpg   Rust repair thread-img_6139.jpg   Rust repair thread-img_6161.jpg   Rust repair thread-img_6167.jpg   Rust repair thread-img_6160.jpg
Old May 15, 2017 | 10:31 PM
krismax's Avatar
Father of the 00 VI
Quarter panel (wheel well)
krismax's Avatar
Father of the 00 VI
Under body spot (under passenger front seat)
First picture untouched
second picture :clean up with grinder.Metal is gone i believe that is the tar sound deadening .it is the only thing between the outside and the carpet.
Attached Thumbnails Rust repair thread-img_6084.jpg   Rust repair thread-img_6428.jpg
Old May 15, 2017 | 10:35 PM
krismax's Avatar
Father of the 00 VI
Passenger under front door rocker seam
second picture . I like to use a grinder, to get the loose thick stuff off.
Attached Thumbnails Rust repair thread-img_6087.jpg   Rust repair thread-img_6424.jpg
Old Jul 19, 2017 | 06:16 PM
maximatech12's Avatar
fourth rocker seem crushed by poor jacking .
The 04- maximas have engine cradles?
This eliminates the lower support from holding the C-member?
I have minor rust in and around the body of this 01. Basically Ive sanded the rust spots(usually on the edges around the window) with 180-240 grit. Then prime,paint,clearcoat.
Even if the touch up paint doesnt match too well its better than rust right?
krismax
May 18, 2017 08:20 PM
