2002 maxima
Old Sep 25, 2018 | 06:01 PM
Kim Beck's Avatar
2002 maxima
I have replaced battery today and alternator a month ago. When I put in New battery it ran fine for about 10 min. Then the brake and battery light came back on. When I accelerate it goes off. What could cause this issue
Old Sep 25, 2018 | 10:17 PM
DennisMik's Avatar
The alternator probably failed again. Unfortunately re-built alternators can be hit or miss, especially the ones autozone sells.
Get your voltmeter and do some tests. With the car turned off, measure the voltage across the battery positive and negative terminals. A good battery will measure 12.3 - 12.5 volts if it is fully charged. But if the battery measures around 10 volts, then the battery may have a dead cell. Now start the car. Measure the voltage at the battery again. If the alternator is charging, the voltage should read 13.8 - 14.2 volts. If the voltage reading is the same as before starting the engine, the alternator is kaput.
Old Sep 26, 2018 | 12:29 PM
MichMaxFan's Avatar
If you do prove our that the alternator is bad, the one you put in might be under warranty.
If nit, I suggest having a local electrical shop rebuild it. Then you know for sure what's been done.
98MaximaLoveHate
22
Nov 28, 2020 10:09 AM
leafman27
Jan 9, 2015 09:38 AM
dandjjohnson
Aug 9, 2009 10:29 AM
97MaximaSE
Apr 29, 2005 01:37 PM
h2kFrosty
Mar 19, 2005 02:48 PM
