Convert to metal tensioner and idler SC pulleys
Old Feb 8, 2002 | 04:18 AM
i30krab's Avatar
Vortech has some links on their site and one is a place called Auto Specialities. I called and they will make custom steel coated aluminum idler and tension pulleys to replace the composite pulleys that came with the kit. I'll feel better with these pulleys since I'll be running 12 lbs of boost. Vortech said If a bearing locks up for just a second under high boost the plastic pulley will self destruct!
If anyone is interested, you can also get the pulleys at $85.00 a piece plus shipping and a donation 0f $5.00 to help defray the $65.00 that stillin charged me for the plastic pulleys to send to auto specialties. I must know very soon because it takes 3 weeks to make them! All money must be paid in advance, no hemming and hawing This is cheap insurance for people
Old Feb 8, 2002 | 04:48 AM
Confused's Avatar
Permanent Maxima.org Resident
Good job Ron,, other V-2 owners have already destroyed the pulley without 12lbs of boost. Btw, ASP also makes pulleys for the blower.
http://www.aspracing.com/intro.htm
Old Feb 8, 2002 | 04:57 AM
SteveChicagoSC's Avatar
Yea ASP made my custom 3" pulley.
Old Feb 8, 2002 | 06:35 AM
BlkCat
Re: Convert to metal tensioner and idler SC pulleys
I'm interested. Should I be dealing with you directly on this?
Old Feb 8, 2002 | 06:53 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Ooooooooo.......... How long did it take them to make your 3" pulley?
Old Feb 8, 2002 | 09:50 AM
Chunger's Avatar
My other car is a Hybrid
Brett, how much does ASP charge for the pulleys? If they already have the design... it would probably be best to go with them unless someone has had a problem with theirs... I assume this is for the V2 pulleys.
Old Feb 8, 2002 | 09:54 AM
i30krab's Avatar
Hi Steve,
3"Pulley,wow, most guys brag about being bigger and you're going smaller.
How much boost are you running?
Old Feb 8, 2002 | 09:57 AM
i30krab's Avatar
Re: Re: Convert to metal tensioner and idler SC pulleys
After I send in the pulleys to auto specialties and they measure them, you can deal directly with them. It should be about 10 days.
Old Feb 11, 2002 | 09:32 AM
BlkCat
Re: Re: Re: Convert to metal tensioner and idler SC pulleys
Cool! Keep us up to date on this!
Old Mar 22, 2002 | 02:59 AM
jgadlage's Avatar
Pulley fitment
Will the pulley fit both V1 and V2 versions of the SC or does that even matter. For the idler and tensioner pulley I would think that they would be the same. Only pulleys on the SC would there be a difference right and one would need to be modified?
Old Mar 22, 2002 | 06:39 AM
Y2KevSE's Avatar
Re: Pulley fitment
I'm not sure what you're asking but, I believe V1 idler pulley equals V2 tensioner pulley (V1 retains the OEM tensioner pulley). So what you want to get is the V2 tensioner pulley... this is the 2" diameter pulley with rails.
Old Mar 22, 2002 | 06:53 AM
delio's Avatar
Re: Re: Pulley fitment
I have never heard of a pulley going bad with a V1 kit except for MattP's (IIRC) right before he traded in for the S4. And he had ALOT of miles on his SC. I have a spare one that happened to get thrown in with my new parts from Stillen when I bought the kit used Justin, all in all I don't think this applies really to us V1 owners. Although I would be interested in taking a look at an aluminum idler pulley if ASP has them ready to ship.
Old Mar 22, 2002 | 07:38 AM
Y2KevSE's Avatar
Re: Re: Re: Pulley fitment
Lyt97SC melted his idler pulley for his V1 kit.
Better safe than sorry, D. I say get it.
Old Mar 22, 2002 | 07:45 AM
delio's Avatar
Re: Re: Re: Re: Pulley fitment
got link?
SC comes off tommorrow, might as well do it now...
Old Mar 22, 2002 | 07:47 AM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Pulley fitment
got link?
What size pulley are you putting on?
Old Mar 22, 2002 | 07:52 AM
DanNY's Avatar
Ad·min·is·tra·tor
V1 - uses stock tensioner - idler is bigger than V2
V2 - uses smaller tensioner than stock - idler is smaller than V1
the tensioners and pulley are NOT interchangeable between the V1 and V2.
Old Mar 22, 2002 | 07:56 AM
Y2KevSE's Avatar
But I thought you said the V1 idler pulley was the same as the V2 tensioner pulley.
Old Mar 22, 2002 | 08:02 AM
DanNY's Avatar
Ad·min·is·tra·tor
nope..
the V1 idler pulley is also a plastic pulley..but it's bigger than the one on the V2.
none of the pulleys are the same between the V1 and V2.
Old Mar 22, 2002 | 08:12 AM
delio's Avatar
Re: Re: Re: Re: Re: Re: Pulley fitment
Kevving,
I am staying with the 3.125, I am doing a V2 Upgrade. The noise level from the V1 is killing me. I am also going to be doing an alternator rebuild, Variable Intake Manifold install, new plugs etc... just about everything I can do in the 2 weeks that I will be waiting on Vortech to send me my new blower.
Old Mar 22, 2002 | 08:15 AM
Y2KevSE's Avatar
nope..
Could compensate with the correct belt size, correct?
Get the check yet?
Old Mar 22, 2002 | 08:16 AM
MardiGrasMax's Avatar
My V1 dosent have an "idler" pulley. It just uses the stock tensioner pulley. This is why the V1 plate is superior to the V2 plate.
Old Mar 22, 2002 | 08:18 AM
DanNY's Avatar
Ad·min·is·tra·tor
Get the check yet?
nope...if the idler is too small the belt will rub on to the support bracket of the V1...not good.
nothing yet...joo check PMs?
Old Mar 22, 2002 | 08:20 AM
DanNY's Avatar
Ad·min·is·tra·tor
there should be a black plastic pulley w/ a red center towards the front of the V1 SC plate...close to the frame on the pass side.
Y2KevSE's Avatar
Don't you have an idler pulley on the end of the SC bracket? It's a pulley with rails.
Old Mar 22, 2002 | 08:24 AM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Re: Re: Pulley fitment
Shave the bracket like us V2 owners have to do when we go with a small pulley.
Yes, I do check PMs... did jOO send me one?
Old Mar 22, 2002 | 08:28 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: Re: Re: Pulley fitment
errr...ummm....sureeee..
Old Mar 22, 2002 | 08:33 AM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Pulley fitment
Sure to shaving or sure to PM? V2 owners have to shave the bracket down by about 2mm so the belt won't rub.
I replied... do it!
Old Mar 22, 2002 | 08:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Pulley fitment
I replied... do it!
ok ok..sheesh..
before
after
yeah i was bored.
want one?
Old Mar 22, 2002 | 08:42 AM
Y2KevSE's Avatar
Looks Photoshopped. j/k
Old Mar 22, 2002 | 08:44 AM
DanNY's Avatar
Ad·min·is·tra·tor
when i hit u on the head with it..you'll know it's not photoshopped!
Old Mar 22, 2002 | 09:05 AM
Duhhh, yea, OOOOPS
Old Mar 22, 2002 | 10:05 AM
DanNY's Avatar
Ad·min·is·tra·tor
Duhhh, yea, OOOOPS
its been a while enh?
Old Mar 22, 2002 | 11:20 AM
jgadlage's Avatar
That is the pulley!
This is the idler pulley or the tensioner pulley. One is OEM and allows you to adjustment via a screw while ther other one is a black plastic pulley with the red center. The plastic one is the one that I was inquiring about to see if they had an aluminum or steel replacement for my V1
Old Mar 22, 2002 | 11:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: That is the pulley!
that "can" be arranged..but the bigger plastic pulley is not as prone to melting like the smaller ones.
tensioner pulley - part where u can adjust tension on the belt
idler pulley - pulley that just pushes the belt to a different spot
on your V1 you're talking about the idler pulley that you're looking for.
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
