OK, 245/40/18 on 7.5 wide=ok?
Old Feb 14, 2002 | 09:30 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
i really want to get these tires now and keep looknig for rims but i don't want to commit myself to 8's or wider so just lookiong for opinions. quick, 16 hours left. http://cgi.ebay.com/ebaymotors/aw-cg...item=602019245
-steve
Old Feb 14, 2002 | 10:11 PM
1MAX2NV's Avatar
Good price. But 245 is a bit wide for 7.5"...maybe the money you save on tires you can get the 8" rims Good find. I might pick up a set too.
Old Feb 14, 2002 | 10:22 PM
PhatGuy
I wouldn't do it. You will probably be best off with 8-8.5 if you go 18 especially with 245
Old Feb 15, 2002 | 12:00 AM
emax02's Avatar
Re: OK, 245/40/18 on 7.5 wide=ok?
-steve
Sounds a little risky to me. I thought that the correct size for 18' tires was 235/40/18. I think 245's on 18's would mess up your speedo. Correct me if I am wrong though, becuase I would like to put 245's on my future rims.
Old Feb 15, 2002 | 03:01 AM
NickStam's Avatar
Re: Re: OK, 245/40/18 on 7.5 wide=ok?
i ran 225/40/18 , 245 sounds really wide
Old Feb 15, 2002 | 04:18 AM
TurDz's Avatar
A wider tired WOULD effect the speedometer.
http://www.geocities.com/jgadlage/tirecalc.html
Old Feb 15, 2002 | 04:32 AM
245/40's are more accurate then 235/40's according to the tire calculator at miata.net i think i'm gonna buy it now on these and then look around 18x7.5's are just so easy to find though SO, will they fit if i have to????
Old Feb 15, 2002 | 05:06 AM
97GLES's Avatar
the wheel should be 8.5"
if you put a 245/40 on a 7.5" wheel, the side of the tire near the wheel will be pushed in while the top of the tire will be out. it might make the tire look square. going around hard turns will wear the tire fast around the edges. try to get a 8" or 8.5" wheel. don't forget about the offset of the wheel if you go to high it will rub. try getting something like 38 offset, stay away from 45 or more.
Old Feb 15, 2002 | 05:10 AM
so can your rim guy get me a decent set of say katana's or racing harts. i haven't found much i like but don't want to spend more then like 200-250 TOPS a rim right now. money is tied up elsewhere.
-steve
Old Feb 15, 2002 | 05:23 AM
97GLES's Avatar
-steve
call me at the store 201-420-6792 after 11am. that way we can talk. i'm in new jersey.
Old Feb 15, 2002 | 06:19 AM
AntGVR4's Avatar
steve i run 235 on 7.25 rims .. they bulge just slightly ..
personally it's better to have the tire bulge out a bit past the rim to avoid curb rash to your nice rims ..
Ant
Old Feb 15, 2002 | 06:24 AM
maxse01's Avatar
I have 245/40 18's and my spedo is perfect. I timed it at 60 between 2 mile markers and it was 59 seconds, so it's only off by .5 or less. Yeah, i checked the miata tire size calculator before i bought the tires. 245 isn't too wide, it keeps the awesome power of the VQ to the ground.
02PearlSE
Oct 7, 2015 02:12 AM
DBear
Sep 14, 2015 08:33 PM
jhontelj
Aug 17, 2015 04:07 AM
Dave B
Nov 6, 2000 12:55 PM
mingo
Sep 5, 2000 09:43 AM
