Q to those with Supercharged maxes
1. I was wondering how much boost you guys get with the Stillen kit and how many of you have increased the boost from (I think) 5-7lbs using different pullies and who has gone the highest. I have heard 10.5-11.5 on a 3.125" pulley.
Also how many of you have put in ECU upgrades and which ones?
2. I have been searching around on the org for this information. I have found quite a lot of info but need some clarification to piece it all together.
I will be running turbo at 5-7 lbs boost, should I get 1 step or 2 step colder plugs? My tuner recommends at LEAST 1 step.
So either:
1-step NGK PFR6G-11
2-step NGK PFR7G-11
(platinums)
I have also seen that we should reduce the gap 0.005" for every 50 HP above stock. Is this IN ADDITION to running colder plugs? I believe stock plugs are 0.043", does that sound right?
I have read people recommending BKR6E/7E (coppers) too! So which ones?
Thanks!
So either:
1-step NGK PFR6G-11
2-step NGK PFR7G-11
(platinums)
Thanks!
Lots of questions, most of which you answered yourself. 1 step is plenty for 6 psi, i run mine at about .040. I'm not running any ecu mods at all, everything is peachy with the ignition. I checked my plugs yesterday actually and they looked fine. When running boost, check your plugs frequently, just to be sure everything is running good in the chamber, plugs can tell you a lot.
Re: Q to those with Supercharged maxes
So either:
1-step NGK PFR6G-11
2-step NGK PFR7G-11
(platinums)
Thanks!
So either:
1-step NGK PFR6G-11
2-step NGK PFR7G-11
(platinums)
Thanks!
Highest boost Ive seen is 12, most run 9-10 when changeing. I run 10 now. 12 is pushing it.
Ecu mod worth doing for sure is haltech, though it's expensive and only if you really want to tune it great and with good amount of boost.
1 step colder = about 100hp gain
2 step colder = about 200hp gain
It's a generic rule if your close to one you go with it.
If your only going 5-7 on a turbo go with 1 step.
Re: Re: Q to those with Supercharged maxes
Originally posted by max'n out
6 lbs is stock.
6 lbs is stock.
Re: Re: Re: Q to those with Supercharged maxes
Yours is a 5th gen. Is it much stronger in terms of component parts? I wonder if 4th gens can take 10 lbs of boost.
Re: Re: Re: Re: Q to those with Supercharged maxes
4th is stronger 5th is weaker and can't technolgoy take the boost (tranny) ...for all gens with few mods i say stick to 9, though it depends on how much you wanna do. If you want to put the power down and acually use it you gotta do tranny mods, if you want alot of boost at a point you gotta change piston etc. You get the idea.
As far as tranny goes, what tranny mods do you have in mind? Mine is a 5sp so no VB mod for me!
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Re: Re: Re: Re: Re: Q to those with Supercharged maxes
Huh? 4th gen is stronger? That's news to me! (I am not too familiar with 5th gens)
After what I found out about Don's vb mod, i will never recomend that to anybody at all again.
But for a 4th gen with 10 psi on the tranny I recomend, great clutch, flywheel, short shift kit, at least. If you want to go farther well
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
Re: Re: Re: Re: Re: Re: Q to those with Supercharged maxes
![goofy](https://maxima.org/forums/images/smilies/goof.gif)
Re: Re: Re: Re: Re: Re: Re: Q to those with Supercharged maxes
Originally posted by MadMax95
What did you find out???
Re: Re: Re: Re: Re: Re: Re: Re: Q to those with Supercharged maxes
If it's that his VB mod is the same as a Transgo kit, then save your breath because there different, otherwise, post away... ![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
I'll be telling soon, I just gotta make sure I get it right, I'm not trying to slader him, just very disapointed with what I was told.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Q to those with Supercharged maxes
Originally posted by mtrai760
If it's that his VB mod is the same as a Transgo kit, then save your breath because there different, otherwise, post away...![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Just a quick question:
What other kind of tranny mods are there? I know of the ACT clutch and pressure plate. How about the transmission itself. I know about engine fortification but not much about transmission (gearbox)
www.cattman.com
I am installing mine next week FINALLY! I have had it since OCTOBER, but have been waiting on parts from Hogan yo_its_ok since.
See for more info:
http://forums.maxima.org/showthread.php?threadid=99961
There are many happy users of the quiafe! Cattman has some commments/reviews available. Also, Lyt97 is selling his max and has his quaife forsale, never installed it and he got it at the intro price of $1250 shipped, so this is your chance to save over $220 on it! Get it now!!!!!!! Eric D Wong installed it himself, ask him for feedback. =)
For autos: shadow is planning a LSD kit soon for only $800 preoder, than it goes up to $1000+ , these threads are in parts for sale and GDs!
Peace out!
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Q to those with Supercharged maxes
Relax, your going down the wrong path. You have no clue what Im going to say, all will be explained soon.
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Q to those with Supercharged maxes
Originally posted by The New CLIMAX
Hmm I wonder what was found out. Why the wait?
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
magiconthetire
10-26-2015 09:03 PM
maxima297
09-30-2015 03:32 PM
