addco sway bar
Old Feb 17, 2002 | 08:12 AM
maxman00's Avatar
addco sway bar
I have a 00 max with addco sway bar and whenever I have 1 or more people in the back it tends to make a bottoming out noise when going over bumps. I have been told that is normal, but I don't think so. Does anyone have any insight?????
Old Feb 17, 2002 | 09:28 AM
justmax's Avatar
Well, on my 4th gen, the addco sway bar attaches to the axle, so I'm pretty sure it doesn't matter whether I have a CD case or 3 big fat guys in the back seat...
Maybe it's different on the 5th gen?
Old Feb 17, 2002 | 09:42 AM
Greg's2kGLE's Avatar
Re: addco sway bar
It could be the bushings...I hear that sound sometimes too.
Old Feb 17, 2002 | 09:43 AM
maxman00's Avatar
yeah it attaches to the axel. My bro has a 4th gen and it is the same thing. Very strange????
Old Feb 17, 2002 | 02:04 PM
maxman00's Avatar
Re: Re: addco sway bar
so you think it may be the bushings??? After this snow up hear in Boston gets the hell out, I am going to take a look at it. It has gotten prgressively worse. How many people do usually have in the back???
Don't want to take it off, but I can't deal with it doing that all the time!
Old Feb 17, 2002 | 03:01 PM
WizzaMax's Avatar
Check your rear facing edge of the flat bracket...if it is scored from impacts...then
Try this, it fixed Bernie's on his 2000 GXE.
Look at the mounting bracket for the right side on the cross member. Depending on where the bracket is, you may be touching the lowest portion of the rear suspension closest to the corner bend of the bar...4th genners dont have this problem as much but you will see sliding it three inches to the left when looking at it from the rear will put in in a spot with more clearance.
Happy Motoring!
Old Feb 17, 2002 | 03:46 PM
maxman00's Avatar
Happy Motoring!
thanks for the info! I will check it out.
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
