Need motor help.....
Old Feb 19, 2002 | 05:14 PM
98MAX's Avatar
Car has been starting kind of funny lately. It does not turn over a couple times than start normally like it used to. Now the motor jumps when you start it. The motor turns over once or twice than jumps and starts running. Than today the car did not want to start. Just turns over real slow(like dead battery,but battery not dead) and it threw a check engine light. Now it will start, but turns over real slow and jumps than make a funny noise. I hope I am lucky enouph for it just to be the starter. When the car is running it runs fine, does not jump or stall or anything. runs normal shifts normal and everything. Any suggestions.
Old Feb 19, 2002 | 05:44 PM
Badaxxima's Avatar
Sounds like an electrical problem. Like maybe a short or bad ground in the ignition switch and related wiring, or maybe a bad solenoid on the starter. Hope it helps.
-Justin
Old Feb 19, 2002 | 05:46 PM
98MAX's Avatar
hey anything helps. I quess I will know a little more tomarrow i will read the check engine code. Just did not want to drive down to work tonight. thanx
Old Feb 20, 2002 | 01:07 AM
Steve Marsh's Avatar
check your negative ground cable to the battery! You will need either a 3/8 or 1/2 drive rachet, with an extension and a 12mm socket. Follow the opossite end of the cable down into the well of the engine, at this point just snug the nut to see if it is in need of any tightening? Even a small amount of play with this cable connection can be a menance! Best Wishes, hey keep us posted! 96se auto 164,769 miles all Amsoil lubricants/filtration Redline "Water Wetter" Dunlop SP 5000's 104+ Octane Booster/Sunoco Ultra 94 (red bottle) strict maintenace regimen!
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
