Holy Moly! 3.25 is kickin' ***!
with the help of ever-so-knowledgable-walking-rice-cooker-Keving i got my 3.25 on. 1 freakin *** bolt wasted over 2 hours, i had to drill into my 3.48 to take off the bolt that was stripped, pretty much only had like 30% surface showing on the bolt.. otherwise it was pretty much round...
as far as aligning the alternator to the SC bracket that was a biotch too... #%@%@# that took like over an hour just for that one bolt itself. and Keving lost a screwdriver somewhere inside my engine bay. well.
other than that. max psi i hit tonight was 9 and i let off before my redline. THAT WAS AMAZING.. it was me, Keving, BL97 & Mingo in the car and it was just haulin' away... on our drive to Burger king, which happened to shaft us a freakin' whopper after we took off and looked into the bag once we go home #%#@%
other than that.. it was a pretty much a cool day.
MANG. the car pulls sooooo hard now.
--Ches
--Ches
OMG brian. its freakin nuts. you thought stock pulley is mad quick?
ok . you ever ride in an E36 (aka 95-99 M3)? this is the only way i can relate to the push on my neck when my friend punches it.
i finally got the neck pull with my car! yay!
Originally posted by BrianV
So how much a significant difference is it from 6???
Originally posted by BlancMax
One question, who had to go without their burger?
This will help out the mewbies a bit before they get started.
Cheston do this, drive in second gear up to 4500-5000 RPM, lift off the gas completely and then mash it, I guarantee your passengers will sh~t their pants afterwards.
It's important to lift off the gas completely cause it puts the car's forward accelleration back at base line so when you gun it, it throws all the G's back, if you just ease into it obviously it doesn't slam your neck, but no car would at that case.
Originally posted by PhatGuy
Shouldn't a 5spd Maxima with an SC (especially a 3.25) destroy an e36 M3? If not I see no point in putting an SC on in the first place. Your putting down significantly more power I assume?
It's probably outright faster, but an SC max wouldnt have the same sharp throttle response as the NA M3.
The boost builds with RPM, so the neck pull would be less....
I guess, just me theory, since I havent driven either one of those cars.
Hey now. don't temp me
Naw. the reason why i compared it to the M3 was the PUSH effect the RWD had on the passengers...
man. those guys with the midget are nuts. i can barely get over the fact this Dwarf is soooo nice.
yay yay
yay yay
Originally posted by Cumalot
Cheston, you just put the 3.25 in??? I sold it to you a long time ago, I thought you had it in already. Oh, if you think the 3.25 is great, just imagine a 3.125...
if i did that. then the dwarf would turn in to sleeping beauty. *poof*
I'm buying the SC in two months and I intend to use either a 3.33 or 3.25 pulley. Obviously, I've got the clutch and exhaust covered but I wonder if you could tell me if I need anything else to keep it safe. I know Kev uses an S-AFC and Vortech 8:1 FMU but when do these become necessary as opposed to luxury? BOV and guages will be done too BTW. Thanks!
But the 8:1 FMU disc is a "safe" bet with higher boost levels.
Originally posted by MardiGrasMax
Naaaaa, I ran it for a while. I only got 8.5psi with the dwarf. I had two step colder plugs. My EGT's hit 780c peak, which IMHO is perfect. The car was WAY fast! Plugs looked good to, no signs of detonation or leanness. With 8.5spi and an 8:1 my EGT's only hit 720c, which is to rich.
GohanMax = RiceMax (translated)
Originally posted by Badaxxima
Is What exactly are the ratios you guys are throwing around? A/F ratio or SC compression? Lastly, does AFC stand for Air Flow Controller or Air/Fuel Controller? I know what it does, I've just heard both names.
6:1 = 6psi of fp per 1psi of boost (60psi/fp:6psi/b)
Air/Fuel Controller (its really a just fuel controller)
Thanks for the info. Not to be picky, but isn't 60:6 a 10:1 ratio? Shouldn't 6:1 on 6psi be 36lbs. of fp? Also, is that total fp or fuel pressure increase over factory?
duhhhhhhh, yea
duhhhhhhh, yea
Is an 8:1 FMU pushing;
80psi FP:8psi Boost or
64psi FP:8psi Boost
Disregard the last question in my last post. That's common sense. I'm still a little confused about the ratios though.
64psi FP:8psi Boost
64psi FP:8psi Boost
Peak fuel pressure is 1/2 base fuel pressure before boost, plus the number from this calculation.
FMU = Fuel Management Unit
Nice sig... I'm a Mclaren fan too! Ya think Kimi's got what it takes... Im gonna miss Mika...
Death to Schumi!!!
Death to Schumi!!!
Myself, I'm a Montoya fan - I think he's the next Senna. But I was out at Indy last year for the USGP and those McLarens sounded fierce! Those F1 cars already rev to 17,000+ rpms and the McLaren's sounded like they were revving even higher. I later found out the sound was due to an unusual exhaust header they used, but they still sounded awesome...
Hey Mardi
do you think if i run 6:1 it will be ok? why dont they have a 7:1
Hey Mardi
Vortech does sell a bleader valve that attaches to the FMU vacume port. This allows you to blead off some boost so you can kinda make a 7:1.
Maxdude00
Sep 23, 2001 05:45 PM
