Dynoed my 02 6spd today! With Greddy/RT cat and with and with & without franken ram!
Old Feb 25, 2002 | 04:38 PM
emax02's Avatar
Just got back from the dyno folks! I am pretty happy with my results .
All the #'s are SAE corrected, altitude is about 600 ft and the barometer was 29.92 and the car has 4300 Miles on it.
First off, I dynoed my car about a month ago and my peak power was 221.8 FWTQ & 205.4 FWHP.
Since then I added a Random technology high flow cat(2.5') and a greddy Evolution cat-back exhaust syestem.
So with this new setup my beast mustered up a peak 230.6 FWTQ(4350 RPM) & 214.6 FWHP(6350RPM) .
So the Greddy and RT cat gave me a peak HP/TQ gain of 9.2FWHP /8.8FWTQ
@5400 RPM I gained a maximum TQ gain of 9.7
@6000 RPM I gained a maximum HP gain of 11.0
Not bad for a little exhaust work, huh? theblue I should have taken you up on your bet of me not getting atleast 5 FWHP! haha..
My whole power band has richend with the new exhaust, the whole power band is up about 5-8+ TQ and 7+ HP
I also decided to remove my Franken Ram section and replace it with my oem intake box. The ram section added about 3-5 TQ and 3+ HP through out the whole power band. Not to shaby, and it sounds awesome! Peak HP jumped down to 208.2 with out the franken ram & peak TQ was down to 227.5. So the franken ram gave me an extra 7.4 FWHP! And 3.1 FWTQ. Props to Steve and Matt C for making such a good product! Thanks guys..
One last thing to mention(DAVE!) is that for some reason my max still breathes mutch better then any other dyno I have seen of the 3.5 VQ! My car is still making peak HP at @6350 RPM and holds all of it's power until redline @ 6500 RPM. Also my car is making over 200 FWHP from 4500 RPM-6500 RPM! I say it's the Stillen velocity stack and franken ram, but maybe that's just me.
More dynoes comming soon.
Old Feb 25, 2002 | 04:45 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Very impressive numbers Ewok!
Old Feb 25, 2002 | 04:48 PM
mattattax's Avatar
Nice work, I'm impressed to say the least
Old Feb 25, 2002 | 04:51 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Good job!!!!!!!!!!!!!1
And way to do a little comparison as well
Old Feb 25, 2002 | 04:53 PM
Victim64's Avatar
Congrates Ethan, be sure to keep us posted
Old Feb 25, 2002 | 04:54 PM
emax02's Avatar
I only need a nother 4.3
Old Feb 25, 2002 | 04:56 PM
Chebosto's Avatar
RIceD OuT moDErAtor
hey ethan.. those are great numbers.
yay yay!
time for custom ypipe and headers, eh?
Old Feb 25, 2002 | 04:59 PM
emax02's Avatar
yay yay!
Thanks, word on the street is Stillen will be comming out with some headers very shortly! Also Weapon-R is supost to be comming out with a ECU modification(I wish GForce would!) very shortly. I am going to dyno both them when they come out. My goal for this car is 245 NA FWHP
Old Feb 25, 2002 | 05:06 PM
Victim64's Avatar
I want an ECU upgrade for my poor old 98
Old Feb 25, 2002 | 05:07 PM
Synki's Avatar
Those are pretty good numbers.
Now lets see some track times.
Old Feb 25, 2002 | 05:09 PM
Chebosto's Avatar
RIceD OuT moDErAtor
oooo.. hold off on the weapon R ecu
hehe.. they're um. kinda shady.. hoon talked to them like two monthes ago for a possible 2k ecu.. and things didnt go too well.
Old Feb 25, 2002 | 05:10 PM
gtr_rider's Avatar
192.168.1.1
Look at E bustin out those times! YOu da man, that must be some bills for dynos, eh?
Old Feb 25, 2002 | 05:21 PM
emax02's Avatar
Yep, $125 but I got about good 7 runs in and I was swapping around intake peices.
Cheston, so do you think the weapon R ecu won't help at all? Is it like a glorified Jet chip or something
I added a little pic in my first post of my car on the dyno(it's a little dark)
Old Feb 25, 2002 | 07:25 PM
deezo's Avatar
So your crank HP is around 270???
Old Feb 25, 2002 | 07:33 PM
emax02's Avatar
Yep and about 285 TQ
Old Feb 25, 2002 | 07:40 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
no nissan overrated the engine he's up to about 250hp and 270tq
btw, thanks ethan.
Old Feb 25, 2002 | 07:57 PM
emax02's Avatar
btw, thanks ethan.
No problem but I do not agree with nissan over rating this engine. Just take a look at the automatic tranny dyno #'s. There around 189-198 FWHP(typical loss for a auto making 255 crank HP). I just think that the 6spd trannsmision looses a lot of power.
Old Feb 25, 2002 | 08:04 PM
BottleFedMax's Avatar
Nice numbers Now lets see some impressive timeslips
Old Feb 25, 2002 | 08:05 PM
v6 altimas make the same hp as us.
Old Feb 25, 2002 | 08:15 PM
PhatGuy
Re: Dynoed my 02 6spd today! With Greddy/RT cat and with and with & without franken ram!
Excellent numbers!
I think you have the most powerful NA Maxima to date!
When are you going to install the UDP?
Old Feb 25, 2002 | 08:27 PM
emax02's Avatar
There 5spd tranny puts down as much as our 6spd tranny, therre 5spd is much more effecient. Go compare some auto altima #'s to a maxima and you will see that the maxima does make about 10-15 more HP.
Phayguy, we will see about the UDP dyno, I don't want to dyno my car to often becuase you really have to beat the **** out of this car to get the big HP #'s out of it. The VQ35 needs to get really hot before it performs well, I know it's weird but it's great for racing! Once I get this months credit card bill I will probably order a UDP, so expect results in about 2-4 weeks. When are you going to dyno your RT cat and UDP?
Old Feb 25, 2002 | 08:41 PM
Dave B's Avatar
Not DAVEB the parts guy
Good numbers Ethan!!!! As for your car making power straight to 6400rpms, I still don't buy it. I don't know what the problem is, but it just doesn't make sense that your Maxima has a much higher volumetric efficency than any other 2k2 on the market. The peak rpms won't change, even if you put and intake and exhaust on. The values might change, but not the peal rpms. The only way to increase usable rpm is to either add forced induction or revise the intake manifold. Your power is right in line with every other 6 speed 2k2 Maxima out there, the only difference is your power peak rpms.
Why not take that 2k2 to track and prove me wrong BTW, throw that G-Tech out the window on the way to the track Seriously, run your G-tech at the track and you'll what many of us have been saying about the G-Tech (ie inaccurate).
Dave
Old Feb 25, 2002 | 08:56 PM
emax02's Avatar
Dave
Argh.. With out my franken ram I did not get the big power peak at the high RPM's, so it's not the dyno. We hooked up clylinder # one and we went over everything twice, I told him you thought something was wrong with the dyno and he just shook his head. My whole power band is simalar to all the other ones until 5400 RPM's, at that point my car just holds the power and even creates more power. Also my whole power band is identical to the last one(just a little higher).
, I'm telling you it's not a screw up.
I am going to "try" to go to the track this spring, the catch is that closest track is almost 2 hours away.
Would you maybe beleive me if I go out and buy a scanner tomarrow and scan my graphs in? I'm telling you, my car's just a factory freak
One more thing to back up my car's high end power band. I race my friends mustang about 10 times a week and we are literaly door to door from 0-95 MPH. On several occasion I have tried shifting at a idicated 6500 RPM(6100 RPM really) and he pulls on me, when I shift at 6900 RPM(6400 really) he never pulls on me, infact I pull a little on him. To me thats more then enough proof. He even said that my car was a lot faster the first time I stated shifting at 6900 RPM
Old Feb 25, 2002 | 09:06 PM
emax02's Avatar
Dave check out Steves dyno: http://www.frankencar.com/product_i/...o_after_lg.jpg .
My plot is identical to his, our intake mainifoldds switch at the exact same RPM and all. The only difference is his car jumps up in power at about 5800-6000 RPM, my power jump is identical in shape and length except that my car jumps at 6200-6400.
Old Feb 25, 2002 | 09:09 PM
i need a port polish job on my intake.
Old Feb 25, 2002 | 09:20 PM
BioMaxDDS's Avatar
Ethan, I HATE YOU
I love your tail lights soooo much, but i'm too chicken to take it apart and do 'em
your car look so much better than mine
Old Feb 25, 2002 | 09:27 PM
Originally posted by tapwr3000
Ethan, I HATE YOU
mine are getting done body color on wednesday.
Old Feb 25, 2002 | 09:30 PM
emax02's Avatar
Make sure to post some pics
Old Feb 25, 2002 | 09:33 PM
i will i finally broke down and got a digicam. i'm thinking just circles for the brake/turn signal part though, not the oval.
Old Feb 25, 2002 | 09:55 PM
freeze2k2's Avatar
Hmm......6speed to 5speed swap?
Old Feb 25, 2002 | 09:56 PM
Snafu's Avatar
Nice numbers!
Just wondering how much did you spend on all those mods to get those new numbers.
Congrats
Old Feb 25, 2002 | 10:00 PM
freeze2k2's Avatar
how is the sound with the greddy and r/t cat? What i mean by that is it quite loud?
Old Feb 25, 2002 | 10:07 PM
emax02's Avatar
Re: Re: Dynoed my 02 6spd today! With Greddy/RT cat and with and with & without franken ram!
Originally posted by Snafu
Nice numbers!
Congrats
I got great deals on both the RT cat and greddy exhaust threw Group deals on the org. The Greddy cost me $474 shipped and the RT cat/hardware kit cost me $175 shipped. The install was free since I did it my self, so all and all not to bad.
freeze00, the car sounds amazing. A nice deep growl comes from the intake and exhaust. The setup is just right IMO, not to loud and not to quite, drowning is almost none existant. Friends say it sounds like I have a big B8 under the hood
Old Feb 25, 2002 | 10:49 PM
Hey Ethan I can't wait till the next meet so I can check out your car. I know its a bit of a ride for you but any chance you'll be at NED on April 3?
Old Feb 25, 2002 | 10:55 PM
emax02's Avatar
Probably not, but I should be at the next MA meet
Old Feb 26, 2002 | 04:17 AM
grr i need some competition man, it wouild be close, even though you got the catback, i got my new borderline drag radials for tires and i'm looking for 2.0x short times
-steve
Old Feb 26, 2002 | 05:37 AM
theblue's Avatar
Not bad at all! But I still am not sure that I give your exhaust/cat too much credit because look at akrus' run and you just don't show much over him (he only has an intake).
Old Feb 26, 2002 | 06:03 AM
AndyXXL's Avatar
Will you go 60mph and make sharp turns with e-brake on the parking lot and with me in the car again?
Old Feb 26, 2002 | 06:12 AM
HondaKiller718's Avatar
Re: Re: Re: Dynoed my 02 6spd today! With Greddy/RT cat and with and with & without franken ram!
Once you can get a down pipe for your car the sound will increase. V12 anyone???
Old Feb 26, 2002 | 07:30 AM
madmax2k's Avatar
Nice gains with your work!
Something still doesnt seem right with a 255 crank hp engine making only around 205 whp stock. I dont buy that the trans is causing a 20% loss. It seems to me Nissan fudged some numbers. Isnt it suspicious that, at the last minute, they dropped the rating from 260 to 255 hp? (Ditto what they did on the Sentra?) That 255 hp still seems like a stretch. Id say its more like 240 hp tops. They gained a crapload of torque (30+ w ft lb), but maybe only 10-15 whp in going to the 3.5L. But, it still should make for a significantly quicker car due to the average power being greater over the usable rpm band.
