How important is it to have adjustable shocks?
Old Feb 27, 2002 | 07:32 AM
soundmike's Avatar
Very sound, Mike
Aside from the control over things, how important is it if someone (like me for example) don't go around racing a lot or running at the track?
Say, to just complement lowering springs w/o radically degrading the ride quality are non-adjustables (like the Tokico's) good enough?
Thanks.
- Mike
Old Feb 27, 2002 | 07:45 AM
Gotrice4's Avatar
if you lower your max conservatively, using tokicos or KYB's GR-2's should be fine, but if you drop your max alot and do alot of "spirited" driving, you might be better off looking into adjustables...
Old Feb 27, 2002 | 07:50 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: How important is it to have adjustable shocks?
Then there are kyb agx shocks/struts that are adjustable.
Not sure if that is what you looking for or not.
I have them and it's nice... if you ever drive on the highway for extended periods of time you can change them...also if you drive in the city you can change them.
Maybe I am in left field
Old Feb 27, 2002 | 08:05 AM
soundmike's Avatar
Very sound, Mike
I have the maxspeed springs (roughly 1.7" front and 1.4" rear drop). Would that be considered conservative?
Also, i drive mostly city and there's a TON of potholes and irregular roads. Do you think the Adjustables would be a better alternative?
My rationale was, since the car is used mostly for commuting to-fro work and perhaps some spirited driving on the highways then i doubt if i'll be adjusting anything much.
Then again i never rode on a car with aftermarket shocks so i have no idea how much harsher the ride is going to be. If it's the same as the RSX (we have one in the family) then i'm skipping the non-adjustables altogether. The RSX, though awesome suspension, is too rough for me.
Old Feb 27, 2002 | 08:40 AM
njmaxseltd's Avatar
Based on that statement, you'd be better off with the AGX's. They are much stronger and will help you maintain ride quality while taking the beating that the combination of your springs and poor road conditions will dish out. The GR2s are a great strut, but may not last very long based upon the conditions you will be operating them in.
Old Feb 27, 2002 | 08:49 AM
soundmike's Avatar
Very sound, Mike
AGX's are the one's that Cattman modified for the 5th gen am i correct?
Old Feb 27, 2002 | 09:17 AM
MaximaRider's Avatar
the reason most people are getting the AGX adjustibles is because they are reasonably priced at $370 shipped and will last the life of the car respectively because of the warrantee. I had tokico's on my eibach springs on my old max, ouch after 10k miles they were shiizzzoT
Old Feb 27, 2002 | 10:12 AM
soundmike's Avatar
Very sound, Mike
I've heard the same about the Tokico's. Does anyone have the AGX's that Cattman sells on their 5th gens?
Btw, the adjustments is to change from firm to soft right?
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
