installing neon lights
Old Mar 3, 2002 | 04:04 PM
95emeraldgxe's Avatar
ok, today i was trying to put neon tubes into my friends corolla. I ran them to the cigarette lighter fuse. I connected one wire to the fuse and then started the car, it didnt light up. THen i connected both wires ( the positive and the ground) to both sides of the fuse, but they still didnt work, is there anything that i am doing wrong?
Old Mar 3, 2002 | 04:07 PM
Greg's2kGLE's Avatar
Re: installing neon lights
Don't connect the ground wire to the other part of the fuse. Only the power wire goes to the fuse. Hook up the ground wire to a metal screw or bolt. That should help you.
Old Mar 3, 2002 | 04:12 PM
does it have to be grounded in order for it to work???
Old Mar 3, 2002 | 04:13 PM
Yes
Old Mar 3, 2002 | 06:56 PM
ok - thanks alot........does anyone else have suggestions on the install?
Old Mar 3, 2002 | 06:57 PM
You're welcome.
Old Mar 3, 2002 | 07:04 PM
zman187's Avatar
Thats all you need to know man, it should be fairly from there.
Old Mar 3, 2002 | 09:07 PM
ToYLeT902's Avatar
JET Speed Lab
try his way... then if it still doesnt work, you might have blown a fuse... check it and make sure!
Old Mar 3, 2002 | 10:06 PM
nizmolee's Avatar
seems like electrical. i have my units connected to a switch with ACC, ON/off and ground needles. the wire connected directly to the switch has a fuse, the others dont need this. good luck, its just like installing fog lights. If you have a relay, it can be a pain. your not suppose to bypass that, i still do it anyways.. i can never get relays to work, just use a fuse..
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
