14 lbs of boost
Old Mar 4, 2002 | 09:21 AM
i30krab's Avatar
14 lbs of boost
I was testing my SC today after we installed a 3.125 pulley. Along with this I'm running a mustang impeller which gives me the equivelent of a 3.0 pulley. I'm also running a vortech aftercooler and erl water injection.
In 2nd gear (automatic) I ran up to 7200 rpm and the boost meter read 14 lbs. I was amazed and I called vortech and they said it sounds right! I'm sure the water injection kept my motor together.
Old Mar 4, 2002 | 09:29 AM
Jeff92se's Avatar
I'm needing a caw
WOW!
You are always on the edge man. Nice!
Y2KevSE's Avatar
Rice Boy in Denial =)
7200 on your magic is nice!
Old Mar 4, 2002 | 09:40 AM
i30krab's Avatar
Originally posted by yo_its_ok
* * * * * B O O M * * * * *
Nice man...7200 ? ECU ?
Did I miss something here ?
JWT reprogrammed my computer.
Meanwhile, I talked to Jim this AM and he's sure they're 6 months away from producing cams for the 4th generation.The cams are already welded up. He also has pistons, rods, and springs he imported from Japan. The pistons are dished and will drop compression to 8:1. When the cams are done, I'll pull the engine and rebuild and then add nitrous.
Old Mar 4, 2002 | 09:53 AM
max'n out's Avatar
Some 5th gen rods would be nice.
Old Mar 4, 2002 | 09:54 AM
Sprint's Avatar
3.0 pulley doesn't = 14 PSI
Old Mar 4, 2002 | 09:59 AM
max'n out's Avatar
Yeah but if his engine is reving higher than normal, then so is the s/c so it keeps building boost.
madmax2k's Avatar
At 7200 rpm it might!
Old Mar 4, 2002 | 10:00 AM
Jeff92se's Avatar
I'm needing a caw
Old Mar 4, 2002 | 10:21 AM
Sprint's Avatar
Sprint got p3ni5 envy
so if i had a 7200 rpm redline i could hit 20 PSI
Old Mar 4, 2002 | 10:29 AM
Y2KevSE's Avatar
If you had a 2.35" pulley... probably.
Old Mar 4, 2002 | 10:35 AM
redmaxpa007's Avatar
i SeE what you did therE
i am sure your wouls see 20 psi right before the entire engine went through the hood!!!
Old Mar 4, 2002 | 10:45 AM
i30krab's Avatar
I talked to Rob at NRH today. I lost my reverse, my snap ring broke, so I'm going to send him my tranny and TQ. He will go thru it and do any updates he deems necessary. He is a very knowledgeable guy and his prices are very fair. Thanks for the info!!
Old Mar 4, 2002 | 10:50 AM
LoL...if you had boost in the first place
Unless you talking about tires and Psi again ?
Old Mar 4, 2002 | 10:52 AM
Sprint's Avatar
LoL...if you had boost in the first place...
we arn't talking about tires?
Old Mar 4, 2002 | 11:06 AM
MardiGrasMax's Avatar
14psi, COOL!
Internals will be yummy!
Old Mar 4, 2002 | 11:11 AM
max'n out's Avatar
No problem, did you happen to mention you got his name from me? just curios. He is real knowledgable, blew me out of the water when I went in to talk to him, he just went on a long time about so many different things, and I just told him my goal and he took care of it.
Old Mar 4, 2002 | 11:20 AM
i30krab's Avatar
I will definitely mention your name when he calls me back!
Old Mar 4, 2002 | 11:29 AM
Y2KevSE's Avatar
In the end, 14 lbs. wasn't good news.
Old Mar 4, 2002 | 11:36 AM
1MAX2NV's Avatar
WHAT?? That level 10 tranny didn't hold up after all that work? Level 10 = SHADY
Old Mar 4, 2002 | 11:40 AM
max'n out's Avatar
OOOOOOO You mean to tell me he had the level 10 kit and it din't hold??????? WOOOOOWWW and people are *****ing at me
Old Mar 4, 2002 | 03:31 PM
Synki's Avatar
That is a lot of boost!
And i am liking that redline of yours.
Will you be hitting the track anytime soon after the new trans is in?
Old Mar 4, 2002 | 03:42 PM
SuDZ's Avatar
14 pounds of boost? Nice
SuDZ
Old Mar 13, 2002 | 07:19 PM
SteveChicagoSC's Avatar
Hey Ron, Level 10's not going to fix it?
Old Mar 13, 2002 | 07:45 PM
i30krab's Avatar
No, I'm going to try NRH tranny in maryland
Old Mar 13, 2002 | 07:50 PM
max'n out's Avatar
No, I'm going to try NRG tranny in maryland
You mean NRH with Rob?
Old Mar 13, 2002 | 08:56 PM
1MAX2NV's Avatar
Well..that was a waste of $6K on a full L10 rebuild.
Old Mar 14, 2002 | 12:07 AM
SWEETSOUND2001's Avatar
Old Mar 14, 2002 | 09:59 PM
Lordrandall's Avatar
Hey Ron, when is your next trip to Burbank?
lrdrandall@yahoo.com
Old Mar 14, 2002 | 10:28 PM
i30krab's Avatar
Hi Randy,
I'll probably be in Burbank in 4 weeks if all goes well. Monday I'm taking my car in to have the tranny and motor pulled. I bought some 9:1 pistons and rings and stiffer valve springs from JWT and they will be installed after I get some machining done. They will hone the cylinders, clean up the heads, do a 3 angled valve grind and balance the reciprocating mass. The pistons are from the same 4th gen. engine off a japan car that has a single turbo rated at350 hp. I.ll have to send my rods in for treatment and I hope to pick up a set of copper gaskets. When the car is back together, I'll be headed to JWT for a 75 shot of N2O and a new computer program. Hopefully we can meet up at that time.
Old Mar 15, 2002 | 12:31 AM
If I come to Burbank, can I get a ride?
Old Mar 15, 2002 | 05:29 AM
Confused's Avatar
Permanent Maxima.org Resident
when is this beast ever gonna get to the track?
Hi Randy,
Old Mar 15, 2002 | 06:31 AM
Lime's Avatar
Holy.................................
Wow. Makes me wish I had some $ to spend. JWT is my hero.
Old Mar 15, 2002 | 01:37 PM
gtr_rider's Avatar
192.168.1.1
Hi Randy,
Old Mar 15, 2002 | 10:18 PM
Hi Randy,
Wow, sounds good! If you ask nice I might give you a ride in my mostly stock max.
See you in a few weeks.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
MichMaxFan
Sep 30, 2015 09:18 AM
mpbclutch33
Sep 21, 2015 01:54 PM
