How to take stickers off windows????
Old Nov 20, 2000 | 11:22 AM
fivelitrekiller's Avatar
I am wondering what the best way of removing stickers on windows would be? I would like to remove my two stickers from my rear windshield but it's hard to even lift a corner!!! Is there any type of solution that would make it easier for this type of removal.
TIA,
five
Old Nov 20, 2000 | 11:25 AM
Shadow's Avatar
A razorblade is the easiest way to do it. I have to remove stickers all the time and out of all the methods I've tried, the razor is the easiest. Then get some sort of adhesive remover to get rid of any leftover glue. If you do it right, there shouldn't be too much glue left.
Old Nov 20, 2000 | 03:01 PM
mlocke's Avatar
Remove the adhesive with GoofOff
I watched the window installer when replacing windows in my house and he used Goof Off. It comes in a spray can and is available at any hardware or most larger drugstores (Target, etc).
Old Nov 20, 2000 | 03:29 PM
NickStam's Avatar
Re: Remove the adhesive with GoofOff
I imagine that a heat gun or blow dryer might help too.
Old Nov 20, 2000 | 08:48 PM
turbolaw99's Avatar
Use Goo Gone, if you get any Goof Off on plastic or the clearcoat, you will damage it.
Old Nov 20, 2000 | 09:30 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
goof off is the best for removing stickers by far
Old Nov 21, 2000 | 06:22 AM
jman965765's Avatar
The old hosing it down with windex and razor blade trick has never failed me before.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
