Custom SC Pulleys
Old Mar 13, 2002 | 06:17 PM
i30krab's Avatar
Custom SC Pulleys
Today I received my custom idler and tensioner pulleys from ;
Auto Specialties Plus Inc.
13313 Redfish suite 104
Stafford TX 77477
(281)261-8845
They cost $55.00 each and the quality is much better than stillin. They're made of steel and the bearings are far superior. They make the stillin pulleys look like toys.
If anyone wants them, now you know where to get them!
Old Mar 13, 2002 | 06:47 PM
SteveChicagoSC's Avatar
Yea they made my 3" pulley.
Old Mar 13, 2002 | 06:55 PM
i30krab's Avatar
Re: Custom SC Pulleys
Stafford TX 77477
(281)261-8845
Hi Steve,
Today, I found out that nissan makes a single turbocharged version of our engine and is sold only in japan. Using The pistons will drop the compression ratio to 9:1. They also used beefier valve springs to help with valve float. The rods are the same. I am looking for these pistons so I can drop the compression and add N2O. The rods can be shot peaned and heat treated.
Old Mar 13, 2002 | 07:55 PM
max'n out's Avatar
O kewl, I should have read through everything b4 posting. So the 3" is the 12psi, and you now have aluminum tensiner pulleys, are they the same size any diff other than material?
Old Mar 13, 2002 | 08:01 PM
NickStam's Avatar
Re: Re: Custom SC Pulleys
Hi Steve,
Your talking about the CIMA, right?
Old Mar 13, 2002 | 08:10 PM
i30krab's Avatar
You can get either aluminum or steel pulleys. The aluminum are more expensive and take longer to make. These pulleys are exactly the same size as stillins.
Old Mar 13, 2002 | 08:14 PM
max'n out's Avatar
Stillen does not make a 3" supercharger pulley nor does vortech, and neither make idler and tensioner pulleys at all.
Old Mar 13, 2002 | 08:53 PM
Shadow's Avatar
Well, I think he means the idler and tensioner pulleys are the same size. Stillen and Vortech may not make them, but somebody makes them for Stillen.
Apr 16, 2020 05:15 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
