Burnout Videos (merged threads)
#84
How do you do the stationary burnout? (when I pull e-brake the car just drags) Also, whats is the bleech for?
Originally posted by SuDZ
For some reason I have always liked them. I dont know what it is about them but I always haev.
SuDZ
SuDZ
#85
i used the e-brake and wheel blocks, and the bleach makes the tires slippery and smokes more.
#87
Originally posted by Stereodude
Because you don't have a LSD. So once one wheel starts spinning it will just keep spinning. No torque will go to the non spinning wheel so the car just sits there.
Stereodude
Stereodude
#88
Originally posted by Craig Mack
Hmm...is this the same thing for stangs ? My friend w/ a 2000 V6 5spd stang, pretty heavily modded, burned out w/o holding down the e-brake..he sat there and spun and then took off...how do you explain that He is RWD but isn't the same principle? (One wheel drive)
#90
Originally posted by sx7r
he didn't use the e-brake. he just stepped on the brake pedal. that's how you do a burnout in a RWD car. it just wastes your rear brakes.
#91
Originally posted by mattC
... why dont you...
wait... you drive an auto...
... why dont you...
#92
Stuck at home on 56K
so I haven't seen the vid yet, I will Friday at work. Did you have burnt rubber stuck to your paint? I had a 70 340 Cuda and an 89 5.0 and I learned the hard way that you should spray your rear quarters with Pam cooking spray before a massive burnout, it makes wiping off the excess burnt rubber so much easier.
#93
I see...and FWD burnout's wastes your e-brakes right? RWD seems easier, while FWD requires more "hands on" for burning out.
#94
no, FWD burnouts just waste your front tires. the e-brake basically just holds your rear wheels in place. the rear wheels aren't spinning so you aren't wasting brake pads - just your tires.
Thanks for the info guy
#110
ok the rims are Zigen MO-5 Inperio 18x7.5 with BF goodrich g-force TA Kd's and it was done in second gear i could have had third too. the third gen is a 93 SE 5-spd it's my friends.
i already had a headache for hours ammonia would have killed me.
#111
#113
Cool video. A feww years back I made a video with my Mustang friends called "Fat, Drunk, and Stupid" (Animal House line). Anyways, we've got a segment of burnouts. We've got a 90 LX 5.0, 95 GT, and 98 GT all doing burnouts on a very slight incline. Then you've got my Maxima which only has a POP intake and 17s. Just to prove to friend I could do it, I pulled the e-brake and got the tires to spin hard thru 1st, then released the e-brake, shifted to 2nd and literally sat still for a second or two before I let off a little and got a little traction and started accelerating. With RWD cars it is far easier to "sit and spin" thru the gears.
With my 17s, straightline traction SUCKED!!! Short sidewalls and a wide and narrow contact patch is horrible for the straightline, but good for turns. When I use to hit 2nd hard, I would spin quite a ways before hooking up. Now, with taller 215/55R16 (vs 235/45R17) tires and a much lighter tire/rim combo, I can launch much harder on and off the track and I usually only chirp into 2nd now.
It is easy to do a burnout with a 5 speed without using the e-brake. It's also easy to spin the tires from a roll in 1st at any speed. Even with my better tire/rim combo, traction in 1st is still hard to come by and I still can't harness all the power, but that's just a downside to having good torque in a FWD car.
Dave
Dave
#114
Re: i dont feel like reading 4 pages...
Originally posted by My 4DSC
so if this question was asked already i apologize...
What gear was that burnout done in...1st or 2nd?
#116
started in 1st, went to 2nd, could have went to third but didnt bother...
... yeah the rear wheels were blocked and we also used the e-brake.
AaronL
08-08-2020 10:31 AM
Need help
23
10-02-2015 08:56 AM
rbaker100
09-25-2015 07:52 PM
