Oil pressure switch....only one wire?
Old Mar 14, 2002 | 08:07 PM
1MAX2NV's Avatar
How does it work? Does this wire get a ground connection when there is no oil pressure?
Old Mar 15, 2002 | 08:15 AM
dwapenyi's Avatar
Re: Oil pressure switch....only one wire?
Since it's attached to the engine block, it's probably using it's casing to ground thru the block.
DW
Old Mar 15, 2002 | 09:05 AM
Matt93SE's Avatar
STFU n00b!
there's simply a spring inside the switch.. when the oil pressure is too low, the spring is closed, letting the switch connect to ground (and the oil light comes on).
when the pressure rises, it releases the ground connection and opens the circuit.. light goes off.
Old Mar 15, 2002 | 09:16 AM
1MAX2NV's Avatar
Cool...thanks. The OEM one grounds itself. I'm replacing the oil pressure switch with an aftermarket unit. The aftermarket one doesn't ground itself. I had to connect a ground wire to one of the two terminals.
The Frye
Sep 2, 2021 11:03 AM
ag90fox
Sep 9, 2015 12:22 PM
