check this idle problem
Old Mar 23, 2002 | 10:38 AM
catman316's Avatar
After my car came out from the mechanic (auto tranny rebuild) I noticed this problem:
When I turn my car on the rpms are like 800 to 1k but when I turn on the A/C the revs drop to like 550-600and when I put the D the car olmosts shut off.
some time i start the car and the rpms are like 1700 to 2k and the car begins to drop and up the rpms very quick and I have to turn the A/C on to drop the RPMS to like 1100.
Some times when i start the car the rpm are low (800) but when i drive and i stop are high (1800)!!!!
The car its suposed to automaticaly lift the rpms when I turn the A/C on so the should be in the same pos when the a/c is on or off.
Like 2 years ago I experience the same pro but was unplugged plug from the IACV-ACC valve and when I plugged it was fix but I check the plug and was plugged. I plug and unplug it several times to see what happend and nothing.
Have any one a sugestion for this problem?
BTW:
the new IACV-AAC valve its like 145 from courtesy
Old Mar 23, 2002 | 03:08 PM
catman316's Avatar
anybody?????
please guys help me.
Old Mar 23, 2002 | 11:00 PM
Andrew's Avatar
Re: anybody?????
bring it to the dealer..let them run a test on it
Old Mar 24, 2002 | 06:24 AM
catman316's Avatar
Im planning to do it but I will try to fix it myself first,
Anyone knows whats my problem?
Old Mar 27, 2002 | 09:51 AM
MIXXMAX's Avatar
RE: Idle problem
Same thing happened to me. It sure sounds that your IACV-AAC is bad. The dealer replaced mine under warranty after 60,000 miles. This definitely cured my problem, except I had to adjust the Idle adjustment screw to get the RPMs down to normal idling. No problems since then, and I'm well over 100,000 miles. I hope this helped. Good Luck!
Old Mar 27, 2002 | 12:37 PM
mango95se's Avatar
Re: RE: Idle problem
My IACV also was replaced at about 50k under warranty. My problems were different, mostly associated with cold weather. It didn't like cold starts - it would rev really low and sometimes even stall. I had to take it to a couple different dealers to find it, but it's been fixed and no problems since.
Old Mar 27, 2002 | 05:49 PM
catman316's Avatar
How much did the new IACV-AAC cost?(I know you didnt pay but they didnt told you how much?
Old Mar 28, 2002 | 06:56 AM
mango95se's Avatar
RE: Idle problem
I cannot remember how much. with labor and all, it would have been around $400 - i caught a peek at the invoice they use to charge to the Nissan warranty - but i cannot remember how much the part costed. maybe you can get a quote from Courtesy Nissan or nissanparts.cc.
good luck!
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
nbstriker10
Sep 4, 2015 04:26 PM
mikebla
Sep 3, 2015 05:37 PM
crazyespn
Sep 3, 2015 01:30 PM
