ECU codes post 5Spd Conversion
Old Mar 30, 2002 | 05:38 PM
skeelo34's Avatar
This is pretty much for anyone that is curious as to what ECU codes they will get after doing a 5spd conversion. This is from my personal experience. Almost all are related to the auto tranny. I think I read somewhere that getting a manual ecu will solve the ECU light coming on.
These are the codes I get (I would assume anyone else doing the conversion will get the same):
4-1 (Intake Air Temp Sensor, most likely just when I kept taking my intake in and out).
5-4 (Automatic Transmission Control Unit Signal to ECU)
11-1 (Inhibitor Switch) ?????I HAVE NO IDEA WHAT THIS IS??????
11-8 (Shift Solenoid Valve A (A/T))
12-1 (Shift Solenoid B (Automatic Transmission))
12-3 (Overrun clutch solenoid valve (Automatic Transmission))
12-4 (Torque Converter clutch solenoid valve (Automatic Transmission))
12-5 (Line Pressure Solenoid Valve (Automatic Transmission))
It took forever to get these damn codes out! (well maybe 10 mins)......
Old Mar 30, 2002 | 05:46 PM
NickStam's Avatar
getting a 5 dp ECU makes sense, although I'm not sure if it works 100%
Old Jun 10, 2002 | 08:09 PM
Yellowbrother's Avatar
Re: ECU codes post 5Spd Conversion
the code i got...
4-1
5-4
9-5
11-8
12-1
12-3
12-4
12-5
Old Jun 10, 2002 | 08:35 PM
dmontzsta's Avatar
Ford Only.
I hope the 5 speed ecu will fix the problem.
220k+ A32
Sep 11, 2015 02:18 AM
ballerchris510
Sep 10, 2015 09:35 PM
Hdnseek
Sep 9, 2015 05:55 AM
mix master
Sep 4, 2015 05:50 PM
