Y pipe question
Old Apr 3, 2002 | 12:37 PM
maxman00's Avatar
Y pipe question
Does anyone know if it is normal for a 2 1/2 Y pipe to have these dimensions?
2 inch down piping and 2 1/2 back from the welds?? I am just a little confused and want to figure out if I got F***ed. I thought it was supposed to be 2 1/2 all the way back???
Old Apr 3, 2002 | 12:52 PM
iwannabmw's Avatar
Re: Y pipe question
Sounds like your pipe was non-mandrel bent.
Old Apr 3, 2002 | 12:59 PM
maxman00's Avatar
Re: Re: Y pipe question
Do you have experience with this?
Old Apr 3, 2002 | 01:02 PM
Nealoc187's Avatar
SLOW
It makes sense to me. whos y-pipe is it? There is less exhaust coming from either bank of 3 cylinders than there is when both banks are combined at the end of the downpipes, so smaller diameter makes sense.
Old Apr 3, 2002 | 01:11 PM
maxman00's Avatar
It is a warpspeed pipe. Your theory does make sense to me, I just wanted to see if anyone has actually measured as well. I was confused because the flow from, 2 1/2 from the top would be better, but maybe there are physical limitations due to header size??? If that is the case then even with 3 inch you would still have 2 from the top.
Old Apr 3, 2002 | 01:19 PM
iwannabmw's Avatar
Re: Re: Re: Y pipe question
Oh, I misread your question. I thought you meant smaller diameter through the bends, not from the exhaust manifold down.
Old Apr 3, 2002 | 07:03 PM
Dan 93 SE's Avatar
WSP y-pipe
The actual size of manifold outlet is a little less than 2". Dallas and I are working on several different configurations, such as honing out the outlet and then use 2.25 down pipes and then using 2.75 from plenum back. This will be for a supercharged car. Who knows? It might work for n/a cars as well.
maxman00 call Dallas or e-mail him, we want to talk top you.
Dan WSP
Old Apr 4, 2002 | 08:48 AM
maxman00's Avatar
Re: WSP y-pipe
I am not sure what you meant here??
So what you are saying is that because of the manifold outlet size, the down pipes will always be 2" unless you can hone the manifold outlet out?
shilov
Feb 19, 2024 09:40 PM
lrb6805
Sep 17, 2015 04:49 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Violator
Sep 9, 2015 10:14 AM
