Dyno Results from Turbocharged Maxima
Hi
Thought you might be interested in the following link:
http://forums.maxima.org/showthread....5&pagenumber=2
pretty soon i'm going to dyno the Shelby Cobra 427 conversion that Jeff92se helped me do the other weekend on my 94 Max........should be interesting to compare the torque curve with the VG and VQ engines.....
Originally posted by sidewinder740
Man I wonder what kind of quarter miles you could get w/that boost!?
I'm thinkin' 11s.........10s if someone wants to donate slicks.
The toughest part was that FWD to RWD conversion......
Show's you for doubting Jeff and I could shoehorn that 427 V-8 in and do the RWD conversion in a weekend...........
Shelby Cobra V8....RWD conversion....someone has $6000 to blow
Originally posted by Craig Mack
I don't care if I sound gullible but did you really do that?
Originally posted by DA-MAX
yup I've seen it!!! Jeff92se helped, hes the master at engine swaps! he putting the Q45 engine in his 3rd gen as we speak.....
Yeah, between doing my original Q45 swap in my 94 and then talking him into helping me with the 427 swap, he's been slackin' on his own "slowass" VE to Q45 V-8 swap..........
Re: So what's next?
Originally posted by turbo97SE
So what do I do now?
I am going to move the engine to the back of the car ro make a RWD car!
Re: Re: So what's next?
Originally posted by VQdriver
those are some unbelievable numbers man. tell me, do you have any driveablity problems at all when driving on either boost level? basically, is there something not perfect about the setup? how does the boost come on? any lag? dude, that is awesome! please perfect that kit. maybe one day i can say that i'm boosted as well
2. The boost actually comes on very quickly (as you can see from the Dynos. It is not as smooth as S/C.
3. Yes there is some lag. It runs close to a S/C (I think) until about 4000 rpm then it really takes off! Matthel had a good reason to use a T3/T4 so he can probably spool up faster and get more acceleration at the bottom end. However, at the same PSI you MAY see some loss at the top or higher end. It al depends about what you want.
4. Anything not perfect? hmmm! I really can't think of anything right now. You have to cut the bumper section to fit the I/C? The oil drain is not the most ideal location for flow, but seems to be working well.
Finkle
09-27-2015 09:53 PM
Team STILLEN
08-10-2015 04:29 PM
